Wind Restrictor
Old Sep 29, 2021 | 12:38 AM
jjhebigscreen's Avatar
jjhebigscreen
Default Wind Restrictor
When I have my seat tilt back lever all the way back my seat rubs with wind restrictor. Any suggestions?
Old Sep 29, 2021 | 03:28 AM
madsonp's Avatar
madsonp
Mine does the same, either don't tilt it all the way back or slide the seat forward a little.
Old Sep 29, 2021 | 08:03 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Seat
Is this a real question ?
Old Sep 29, 2021 | 11:11 AM
ROBOPTI's Avatar
ROBOPTI
Yeah it is a real question ... The only stupid one is your remark ... HATE forum BS
OK ... I have the SAME problem ... I've come up with 2 solutions. I'll put the links below for the products I bought
Currently I have this setup
This a soft silicon disk that takes the crush of the seat to the wind restrictor. It works pretty damn good.
I also tried and MIGHT prefer my other solutions. Went on amazon and bought both 1/8 & 1/4 inch thick foam adhesive squares - and they work great.
Neither are visible with the top down and the back of the seat is black anyway.
Best I could come up with ... and both of my solutions are cheap
Clear silicon door stoppers
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Foam pads
Hope that helps a little
Old Sep 29, 2021 | 01:16 PM
QuesoCaliente's Avatar
QuesoCaliente
Driving around topless. Tired of getting blown. Windschotts! Unwanted rubbing. Need answer.
What's not to understand?
Old Sep 29, 2021 | 01:27 PM
2008 Corvette
Default Restrictor
Originally Posted by QuesoCaliente;[url=tel:1604093534
1604093534[/url]]Driving around topless. Tired of getting blown. Windschotts! Unwanted rubbing. Need answer.
. The simple solution. Don’t lean the seat all the way back
Old Sep 29, 2021 | 02:07 PM
Icecap's Avatar
Icecap
I have the same issue and contacted Windrestrictor about it since the plexiglass was starting to get a rub mark on it as well as the seat leather at the point of contact. Windrestrictor sent me 2 square self adhesive patches of a fabric like 'mouse fur' that I applied and it worked to eliminate the squeeking and the rub blemish. I will eventually rework the mounting brackets to relocate the WR further back since I've done a mock up and can see no issue with relocating it.
As for not moving the seat as far back some of us are hindered by our dimensions and unless the seat is at the extremity of rear position end up having the top of our head directly in the airflow coming over the top of the windshield when the top is down even when the seat is fully lowered. That extra bit of backward lean is just enough to get my head out of the airstream.
Old Sep 30, 2021 | 02:35 PM
jjhebigscreen
Thanks for the information. I called Windrestrictor today and they are sending out pads. That should do the trick.
Old Sep 30, 2021 | 02:42 PM
z06clif's Avatar
z06clif
That first picture looks like a Breast Implant.....
Clif
Old Sep 30, 2021 | 07:29 PM
2008 Corvette
Default Wind
Originally Posted by z06clif;[url=tel:1604099156
1604099156[/url]]That first picture looks like a Breast Implant.....
Clif
.Agreed, Now it’s implants in the back also.
To Wind Restrictor
