oil volume
Old Nov 18, 2021 | 06:39 PM
Crow Hunter's Avatar
Crow Hunter
Default oil volume
Since the oil pump in the LS/LT engines is driven directly off the crankshaft - as opposed to being driven off the camshaft in the SBC and BBC - is twice the volume of oil being pumped through these engines?
Old Nov 18, 2021 | 07:19 PM
double06's Avatar
double06
The pump designs are much different so not sure. Also I think the camshaft gear is twice as big / tooth wise so then I think gets the pump to spin the same as the crank again.
Old Nov 19, 2021 | 02:05 AM
Dano523's Avatar
Dano523
Short answer is no in stock form, but increasing the amount of volume that the stock pump will move can be done by porting it, while increasing the pressure it will push can be increased by increasing the tension on the blow off piston spring.
Good video on how to center the pump when installing it.
Good video between the stock pump, and after market pump.
To add, the old Sb and LB oil pumps were pretty much bolt in place with indexing pins, while on the LS/LT motors, you have to index not only the oil pump, but the timing cover.back cover as well, since they do not have locator dowel pins.
To oil volume
