Good afternoon Corvette family this is easy again with the problem with the service vehicle soon light I purchase a OBD two scanner app first at red P 1035 code then I checked for previous codes I had none or store none or permanent none that is the best but I know that but I tried checking?
Hi Ez...
Quick google search pulled this for your code:
Common Causes of Chevrolet Corvette C6 P1035 OBD2 Code
A common cause of code P1035 is the failure of ABS Outlet Valve Coil RF Circuit Short To Ground, but there are several other possible causes as well, such as ;
Engine Control Module (ECM)
Faulty starter motor
Clogged or faulty fuel injector (s)
Incorrect fuel pressure
