Brake Fluid Flush
Old Dec 12, 2021 | 10:37 PM
like2lean's Avatar
like2lean
Default Brake Fluid Flush
Not sure why domestic cars and many US owners have always been resistant to many fluid changes, not the least of which is brake fluid. I know it's not in most of the manuals, but all import and even most motorcycle manufacturers understand the need. Someone at FedEx lost (stole) one of my wheels so while waiting for the replacement I thought I'd change the brake fluid a bit earlier than I normally would. This fluid has only 25k of very easy service, and knowing new fluid is gin clear should make anyone a believer.
Old Dec 13, 2021 | 08:48 AM
pbergmann's Avatar
pbergmann
Ditto!!!
It also keeps the ABS system happy.
Been doing this on my C3, 4, and C5'S for years.
Old Dec 13, 2021 | 09:37 AM
81VETTOM's Avatar
81VETTOM
Agree some of the best time & money spent
Old Dec 13, 2021 | 09:50 AM
BadAV's Avatar
BadAV
I started doing brake flushes about 20 years ago. I guess they are like most people view differential flushes, and to a large extent auto transmission pan drop/filter changes - unnecessary.
Old Dec 13, 2021 | 10:01 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I also when have the fluids flushed add brake system so everything is clean for the next 5 years.
Why take the risk, pf problems. In fact this coming April having all the fluids changed again.
Old Dec 13, 2021 | 10:16 AM
Spaceme1117's Avatar
Spaceme1117
I like to change my brake fluid every year. Realistically, its not age that hurts to fluid it is the hygroscopic nature of the brake fluid. It absorbs water and lowers the boiling point.
So if you live in a climate that is very humid or there are a lot of temperature swings, you should be changing your fluid more frequently.
Get a Power Bleeder and make it super easy to do.
Old Dec 13, 2021 | 12:27 PM
Dano523's Avatar
Dano523
Service manual calls out for the brake fluid to be flushed every two years.
With how dirty the fluid is, that a lot of seal rubber, humidity, and god only knows what kind of humidity damage to the walls on the cylinders from not power flushing the fluid for a decade of more isntead.
Myself, if you are still waiting on rims, would take the time to remove the calipers, pull them apart, and do a clean up on the pistons and cylinders as well. If you use silicone to re-grease the seals and dust shields before they are reinstalled once cleaned up (or just go heavy on the clean brake fluid to keep them wet once cleaned up), can use the old rubber parts to put them back together (just keep the piston and it part back in the same channel,or just pick up a new set of seals and dust shields). Hence, even with the system power flushed, you still have a lot of crap in the calipers piston channels on the bottom that is just going to keep contaminating the fluid again.
Old Dec 13, 2021 | 01:41 PM
Frank4202's Avatar
Frank4202
You're a brave man......... for using your wifes measuring cup
Old Dec 13, 2021 | 02:05 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Not my wife she doesn't no what it's used for, doesn't cook nothing, if she did I would probably be dead!
Old Dec 13, 2021 | 03:50 PM
like2lean's Avatar
like2lean
Lol, she gave it to me after I used it the first time!
Originally Posted by Dano523
Service manual calls out for the brake fluid to be flushed every two years. Myself, if you are still waiting on rims, would take the time to remove the calipers, pull them apart, and do a clean up on the pistons and cylinders as well. If you use silicone to re-grease the seals and dust shields before they are reinstalled once cleaned up (or just go heavy on the clean brake fluid to keep them wet once cleaned up), can use the old rubber parts to put them back together (just keep the piston and it part back in the same channel,or just pick up a new set of seals and dust shields). Hence, even with the system power flushed, you still have a lot of crap in the calipers piston channels on the bottom that is just going to keep contaminating the fluid again.
I couldn't find a recommendation in my 08 manual, where is it in yours?
You're so right about the sludge and hard deposits that form in calipers and wheel cylinders for that matter, most would never believe it unless they saw. It's crazy how much crap you find in them even on a perfectly functioning brake system.
Old Dec 13, 2021 | 09:40 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
I change brake fluid often on a track car. I replace the bleeder screws with Speed bleeder fittings. It is a very simple one man job.
I think the most over looked fluid change is the power steering fluid. It is more time consuming but easy to do if you know the tricks.
Old Dec 14, 2021 | 12:06 AM
vetteJPJ's Avatar
vetteJPJ
So what are the tricks?
Old Dec 14, 2021 | 06:49 AM
449er's Avatar
449er
CF Community Team
lol
Old Dec 14, 2021 | 01:06 PM
dr_gallup's Avatar
dr_gallup
Those PYREX borosilicate cups are collectors items these days. The ones being sold now are Pyrex (not all caps) and made of cheap soda-lime glass.
Old Dec 14, 2021 | 07:44 PM
Keppler's Avatar
Keppler
I have a 2009 Z06.
The short version is:
You need to make some room.
Remove the air intake tube going into the throttle body.
Remove the upper radiator bracket that runs across the radiator.
Drain a little coolant.
Loosen the upper radiator hose at the engine. Remove the upper radiator hose at the radiator.
Rotate the radiator hose 90 degrees upwards.
Purchase a cheap 6" diameter tin funnel. Squish it to fit between the engine and the radiator underneath the power steering reservoir.
Run tubing from the funnel to a container on the floor.
Leave the reservoir cap on. Pull the lower reservoir hose off the PS reservoir. Immediately cap off the port with a vacuum cap. The lower return line goes into the funnel.
The rest of the job is running a few bottles of fluid through to purge the system.
Using the large funnel you won't spill a drop. The youtube guys pull the PS hose and let the fluid run everywhere.
To Brake Fluid Flush
