Harmonic balancer 2012
Old Dec 19, 2021 | 01:39 PM
robbie shirkowski's Avatar
robbie shirkowski
Default Harmonic balancer 2012
Did gm fix the wobble in the 2012 grand sport from the older c6"s? Is it as common of a problem ?
Old Dec 19, 2021 | 02:56 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
No. You’re on your own.
Old Dec 19, 2021 | 06:33 PM
HK770's Avatar
HK770
Had to replace my 11 Grand Sport Damper. I am given to understand even (13 s) had the same problem.
Old Dec 19, 2021 | 06:35 PM
208vette's Avatar
208vette
I have a '12 and the HB started to wobble around 45k. By 50k it had become much worse and I parked it until I could replace the HB.
Old Dec 19, 2021 | 06:45 PM
gdmoore01's Avatar
gdmoore01
All C6 Corvette's can suffer from the problem with HB wobble. Also, it is apparently a common enough issue to rank within the top 10 repair topics (IMO) on this forum. If the car has a stock balancer, check for the condition often and the need for replacement is also commonly preceded by a belt chirp at start-up.
Good luck.
GD
Old Dec 20, 2021 | 01:23 PM
rbwinston's Avatar
rbwinston
Lots of write ups about it here and on the internet. Several good video's if you're interested in doing it yourself. Don't take it to a "stealer" because that's exactly what they'll do !!! Find a competent shop, preferably a Corvette shop, or at least someone who's done them before.
Old Dec 21, 2021 | 01:26 PM
TecCrash's Avatar
TecCrash
Did you have a local shop do it, and if so may I ask who and how much? Getting ready to put mine on the lift next month and do ours.
Thanks!
Old Dec 21, 2021 | 03:03 PM
208vette's Avatar
208vette
Thanks!
Yes I did have a performance shop in Boise do it. I got the ATI balancer which is pretty pricey but the best one in my opinion. You can save a couple hundred going with the Summit brand or Powerbond. Labor will be around 7 hrs. Total was around $1200, would probably have been under $1000 without the ATI.
To Harmonic balancer 2012
