MGW Flatstick shifter issue
In gear it can be moved around laterally and wherever you move it, it’ll stay rather than spring back.
Any idea what this might be? I tried to attach a video showing what I’m talking about, but it wouldn’t let me.
https://youtu.be/KEgvKvO3P3k
I followed the C6 install video from MGW and it doesn't talk about tucking the ring of the boot below the bottom of the boot on the shifter. It just says to make the two boots look like one piece. (See how it looks at 13:40 )
My shifter is pretty stiff trying to move to the 1-2 gate or 5-6 gate from the 3-4 line. I just thought I needed to do the anti-venom mod but it looks like I need to get back under there and tuck the boot down lower.
As shown, mine just sits around the MGW boot like the C6 video shows and I added white lithium grease to keep the friction down. My only complaint with the MGW so far has been how difficult it is to move horizontally, and this hopefully explains why.
I'll try this and if it doesn't change things, I'll do the anti-venom when I change the transmission fluid in the spring.
If you want to grease any of the rubber parts, you need to use a silicone base grease that will condition the rubber at the same time to keep it playable/will not cause it to become more soft and swell instead.
If boot is cut and installed correctly, it will always pull the shifter shaft back to center.
So question now comes down to if the lower box with trans linkage was not indexed correctly at install that is causing the return problem (did you use the index plate), is the ball to box linkage the problem that is causing binding problems ,or is the trans shaft/tran's internal linkage causing the binding problem instead.
If I had to take a stab at it, when you pulled the old shifter linkage out of the old box, did not take the time to clean up the rod surface, and its bur on the box shaft that is causing binding on the nylon bushings that it runs through.
Short of that, its the upper shifter shaft assembly that is binding up it it pivot movement, and just needs to adjusted/may need to send it back to be adjusted.
https://youtu.be/W9Zly20AWt0
I cleaned up the rod surface when I took the old lower assembly out and I lubed it up with a bit of the extra lube that came with the MGW shifter when putting the new lower box together.
I also used the alignment tool so I'm not sure how I could have messed it up. I guess I should explain the situation to MGW customer service and see what they say. If I'm stopped with the car running, it's almost impossible for me to get it into 5th gear because the force it takes directs me right to reverse. The sweet spot to get to 5th is hard to get to because of the tension. When I'm driving it's not an issue because of the reverse lockout. Never had any issues finding gears with the OEM shifter. I liked how smooth that one was, but I do like the notchiness and tightness of the MGW.
How would I know if it's an internal transmission issue? One other symptom I've been getting is the car will sometimes grind when going into 2nd when cold. I know this is a fairly common issue but it only happened once in the past 10k miles with the stock shifter and has probably done it 5 times in the last 500 miles with the MGW. It's almost like it doesn't have enough leverage to throw it past the synchros into 2nd. That's why I'm planning to change the tranny fluid when it's a little warmer out and send the old fluid to Blackstone Labs.
When I installed my MGW some years ago I did not have the transmission shaft correctly oriented with the lower box, it looked like it was aligned so I tightened the pinch bolt and put everything back together. After a test drive finding the 5 -6 gate was difficult, it seemed like the shifter was going all the way to the reverse gate, but still going into 5th gear. After taking the console apart I found the transmission shaft was off just a little bit, the concave portion of the transmission was twisted ever so slightly so that although the pinch bolt was tight, there was slop in the lateral movement. I slightly loosened the pinch bolt, then carefully made sure the concave cutout on the transmission shaft was vertical as I re-tightened the pinch bolt. No problems since.
Good luck, and let us know the resolution.
Edit: To help OP, based on what I heard from MGW, you should check the bolt that goes into the notch of the shift linkage rod. Procedure described above. Do you have any issues getting into reverse? Can check these things without taking the console apart again, otherwise I'd call MGW and see what they say. They have been super helpful for me both during the ordering process and troubleshooting.
