Mode door actuators
Old Dec 23, 2021 | 10:41 AM
Robman's Avatar
Robman
Default Mode door actuators
I知 about to pull the dash and replace the mode door. Does anyone know the part numbers for all the actuators so I can replace them all while I知 in there. Also is there anything else I need while I知 in there?
Old Dec 23, 2021 | 10:50 AM
09LS3's Avatar
09LS3
If you have HUD, you could look at reinforcing the support pins for the rotating assembly.
Old Dec 23, 2021 | 11:16 AM
Robman's Avatar
Robman
yeah already been there done that😂
Old Dec 23, 2021 | 06:37 PM
4SUMERZ's Avatar
4SUMERZ
Here is the pages that shows all the actuators and part numbers. It's from a 2009 but they should be the same for all years.
Good Luck
File Type: pdf
Old Dec 23, 2021 | 07:54 PM
Robman's Avatar
Robman
Good Luck
Old Dec 23, 2021 | 07:55 PM
HK770's Avatar
HK770
For my 11 hope it helps
https://www.wholesalegmpartsonline.c...rimLevel=25571
To Mode door actuators
