Shift boot for a Hurst shifter?
Old Dec 26, 2021 | 08:57 AM
Cryptoboy's Avatar
Cryptoboy
Default Shift boot for a Hurst shifter?
Done a few searches in here and different sites but haven’t found what I was looking for.
I installed a Hurst shifter a few months back (purchased on here) and while I like it (it’s stiff but in a goof way) - the stock shift boot is loose on the shifter. It lets a little heat in at times, and just don’t like that It’s loose.
What suggestions can anyone make? I hesitated buying an aftermarket since they look like I’d have that same gap.
Old Dec 26, 2021 | 11:51 PM
Patsgarage's Avatar
Patsgarage
If the boot is just loose around the top you could try a local upholstery shop. They should be able to use your old boot as a pattern and juts make the top fit more snugly. I had a console cover custom made by a local shop for less than the cost of a new aftermarket one, so it may cost less than you think.
Old Dec 27, 2021 | 05:16 PM
madsonp's Avatar
madsonp
Perhaps you could just put a zip tie around the top.
To Shift boot for a Hurst shifter?
