C6 Corvette fuel pump replacement
Old Jan 11, 2022 | 05:14 PM
C6fromtheD's Avatar
C6fromtheD
Default C6 Corvette fuel pump replacement
Check out my fuel pump replacement videos on my channel.
https://youtu.be/MMsZIVC-y_E
Old Jan 12, 2022 | 11:23 AM
rc51racer's Avatar
rc51racer
Old Jan 12, 2022 | 06:12 PM
JackDidley's Avatar
JackDidley
Part 2 ??
Old Jan 12, 2022 | 06:14 PM
C6fromtheD's Avatar
C6fromtheD
Hello,
just click on my channel name and you will see all my videos including different parts.
Old Jan 12, 2022 | 06:47 PM
v4e2r7t's Avatar
v4e2r7t
Link ->
Old Feb 17, 2022 | 10:05 AM
C6fromtheD's Avatar
C6fromtheD
Well boys and girls I learned a lot and fuel tank is back in. Also figured out my idle issue and why bank 2 fuel trim was off.
Aem gage makes a huge difference when it comes to getting proper parameters out to make sure my C6 is running good.
Old Feb 17, 2022 | 11:06 AM
JackDidley's Avatar
JackDidley
The fuel pump videos you have done are nice. I hope I never need them.
Old Feb 17, 2022 | 11:09 AM
C6fromtheD's Avatar
C6fromtheD
I hear ya, it’s not a fun project but can save you a ton.
important element here is it can be done on a4,A6 and M6 without removing anything but wheel,inner wheel liner and axle back exhaust.
Old Feb 17, 2022 | 07:01 PM
Vicorniner's Avatar
Vicorniner
Nice! Thank you
Old Feb 21, 2022 | 07:23 AM
ittlfly's Avatar
ittlfly
FYI…..long story here but just had all this done by the dlr. final cost, $4125. They did have to pull both tanks because of bad gas and the car sitting for long periods without use. As I said a long story.
Old Feb 21, 2022 | 07:33 AM
C6fromtheD's Avatar
C6fromtheD
That is insane but I would like to hear the story. If it was just old gas or a leak combined with other issues.
Old Feb 21, 2022 | 07:44 AM
449er's Avatar
449er
CF Community Team
There is a ton of labor (especially with an auto trans) required to remove the tanks to get to the affected parts, a dealer would typically charge 3k+ to perform this job
Old Feb 21, 2022 | 07:50 AM
C6fromtheD's Avatar
C6fromtheD
Oh I know. I just upgraded to a z06 fuel pump and Installed it myself.
Old Feb 21, 2022 | 09:10 AM
ittlfly's Avatar
ittlfly
Well…..the Readers Digest version ……Came across 2007 base coupe M6 with 10K on the clock but absolutely loaded and in mint condition for sale at a Tucson AZ dlr. Anyway, drove it home in Phoenix (100 miles) with no issues. However, the first time I really got on it the fuel pump went out. I had owned the car for 14 days at this point. Had it towed to a Chevy dlr in Temple who was owned by the same outfit who sold me the car in Tucson.
They diagnosed it as no fuel pressure. The tech pulled out the left tank and found it varnished and (according to him) the fuel pump fell apart in his hands. Pulled the right tank and found the same problem. So he cleaned out both tanks, installed new pumps, r&r’ed all fuel lines up to the fuel rail. This was all due to the car not being maintained …and not cared for while sitting. As I side bar, I have changed out ALL fluids including power steering fluid.
I bought the car "as is without warrantee". That said, I was able to work out a deal with the dlr so it paid much less than the $4125 bill. I also bought the non-program dlr warrantee as there may be a harmonic balancer or torque tube problems down the road. The moral here is drive your car or at least do your do-diligence before storing it. Ask me how I know.
Old Feb 21, 2022 | 09:47 AM
C6fromtheD's Avatar
C6fromtheD
yep,
ethanol and vehicle sitting will do that for sure.
To C6 Corvette fuel pump replacement
