Programming Key Fobs
Old Jan 21, 2022 | 10:56 PM
Jercon's Avatar
Jercon
8th Gear
Default Programming Key Fobs
Members: I have a problem. I have a 2008 C6 Convertible. Key fob #1 is lost. Key fob #2 has been destroyed. I have the key to open the car and I have ordered two new GM fobs and a blank key. The Question I have is 'Can I program these new fobs if I don't have any of the original fobs'?? I don't even want to talk about what happened to the original fobs! Jeromy.
Old Jan 21, 2022 | 11:38 PM
Vette_DD's Avatar
Vette_DD
Yes, as long as it's not a car that was made for and delivered to someone in Canada.
Old Jan 22, 2022 | 12:11 AM
JackDidley's Avatar
JackDidley
Go here.
https://www.corvetteforum.com/forums...tructions.html
Old Jan 22, 2022 | 08:10 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I would also got to U-tube and watch video of the procedure, and make sure your hatch isn't dirty that you can't the key in there, cause you need start there by turning the key, I think the last time I did mine, turn it 5 times.
Watch the video.
Old Jan 22, 2022 | 09:17 AM
RoadGlide15's Avatar
RoadGlide15
Default Youtube
Auto auction rebuilds has a pretty good video where he programs three fobs using the 30 minute method….I don’t have the link but a YouTube search for him is pretty simple
Old Jan 24, 2022 | 07:39 AM
blownbayou's Avatar
blownbayou
Watch the video.
If your key will not turn (like mine)... Then pull the back cover (inside the hatch) and use your finger to pull the lever 5 times...... Works like a charm.
Old Jan 24, 2022 | 05:45 PM
Dano523's Avatar
Dano523
And again, if C6 was built for export, the rear key cylinder will not put the car into Fob relearn mode.
Old Jan 24, 2022 | 11:21 PM
Rocketmanwpb's Avatar
Rocketmanwpb
C6 Fob, Short Procedure….use these instructions 1-10 when you have a working fob and just want to add another to the system, or to test the operation of the glovebox slot.
1. Put drivers window down all the way, then turn car off
2. Unlock car and open trunk
3. Glove box open
4. Put working fob on console next to shifter (the one you are currently using to drive the car) IMPORTANT. Also make sure no cellphones are in the car.
5. Put key in trunk keyhole and turn key five times in less than 5 seconds.
6. DIC will now beep and light up and say “Ready for fob 3”.
7. Put new unprogrammed fob in slot by glovebox with buttons facing right (passenger) side and keyring facing outwards.
8. Wait and watch DIC. When it says “Ready for fob 4” it is done. Up to four Fobs may be programmed to the car total.
9. When all Fobs are programmed, push OFF/ACC (bottom half of start button) to turn off DIC.
10. Test all four buttons on fob and then take away all other fobs and check car starting with new fob(s).
Testing the glovebox slot above. Step 6 gets the system into the program mode so that if you then put an unknown fob into the slot in step 7, it will be added to the car. If you put the already working fob into the slot in step 7, the DIC will say "KNOWN FOB" and nothing additional will be programmed. When it says KNOWN FOB, it shows you that the slot is working as it has read the fob and told you that it already has that fob programmed to the car. At this point, just push the OFF part of the start button and all is good, no changes made. If , at step 7, you put a known fob in the slot and the DIC does not say KNOWN FOB, then the slot is not working and you should not do the long procedure.
C6 Fob Long Procedure….use these instructions 11-22 to erase car memory and reprogram all Fobs. Be sure to confirm proper operation of the glovebox slot with the short procedure before using this one. Any lost Fobs that are not reprogrammed with this procedure will no longer work on the car. Lost Fobs that are later found may be added to the car with the short programming procedure. This procedure requires three consecutive ten minute waiting periods, so plan on spending about a half hour to do this, during which the car may not be moved. Remember that the number printed on the Fob only indicates the way it was first programmed at the factory. All Fobs are identical. The order in which they are placed in the glovebox slot determines what number the Fob is.
11. Drivers window down, car off
12. Trunk open
13. Glove box open
14. Make sure NO Fobs are anywhere near the car. IMPORTANT.
15. Put key in trunk keyhole and turn key five times in less than 5 seconds.
16. DIC will now beep and light up and say “Off/Acc to learn” If you decide at this point NOT to do the programming now, push the TOP half of the Start button and the car will return to normal. With step 17, all previous fobs will be erased. To continue with programming:
17. Push bottom half of the Start button. DIC will say to wait 10 minutes and will start counting down the minutes. You may close the trunk and car door while waiting for the ten minute countdowns.
18. After the first 10 minute countdown, DIC will again say “Off/Acc to learn”. Push bottom half of Start button again. DIC will again start counting down the ten minutes.
19. After the second 10 minute countdown, DIC will again say “Off/Acc to learn”. Push bottom half of Start button again. DIC will again start counting down the ten minutes.
20. After this third ten minute period is over, DIC will say “Ready for Fob #1” Regardless of the number on the Fob, the FIRST Fob that is put in the glovebox slot will be recognized as Fob #1. Put the first Fob in the glovebox slot with the buttons facing to the right (passenger) side and the keyring end facing outwards.
21. After 3 or four seconds the DIC will beep and say “Ready for Fob #2”. Put the second Fob in the slot. The car will take a maximum of four fobs. When you have no more Fobs to program, push the bottom half of the Start button to end the programming session.
22. Test all buttons on the fobs to make sure they work, then take all fobs away from the car and, one by one, try using each to start the car.
To Programming Key Fobs
