Voltage drop with system
Old Feb 1, 2022 | 07:44 PM
Klawp's Avatar
Klawp
Default Voltage drop with system
Edit: resolved - just using a bad ground !
Old Feb 1, 2022 | 08:17 PM
FatsWaller's Avatar
FatsWaller
400W @ 12V requires over 33 amps. The OEM alternator can't even keep up with the draw from rad fan at idle speeds, so add in all the rest of the electronics and I'm not surprised at what you are seeing.
Old Feb 1, 2022 | 08:33 PM
Klawp's Avatar
Klawp
Figured out the issue. Rookie mistake too considering I sanded down to bare metal. But it's a bad ground. Ran a separate ground from battery directly to amp to test and the settings I had it on never dropped below 14v.
To Voltage drop with system
