2007 corvette
Old Feb 2, 2022 | 09:45 PM
SamRobert's Avatar
SamRobert
5th Gear
Default 2007 corvette
Hi. New guy here. I'm 71 years old and about to buy my first corvette - a 2007 one owner with 83000 miles. The carfax shows that it was serviced regularly, but there are a couple things that concern me. At 70,000 the rack and pinion was replaced. At 72,000 the power steering pump, water pump, front crankshaft oil seal, and crankshaft pulley/balancer were all replaced. I didn't see any mention that the transmission had been serviced. Is this normal for this vehicle? I'm not buying the extended warranty as it is rather pricey. Should I be wary of this car?
Old Feb 2, 2022 | 09:52 PM
JackDidley's Avatar
JackDidley
The balancers are a known problem so that is not unusual and it is normal to do the front seal while there. The other stuff, I am not sure about .
Old Feb 2, 2022 | 11:29 PM
4SUMERZ's Avatar
4SUMERZ
It is possible that the HB issue also caused the steering rack issue as well if it crept that way. As long as all that work was done correctly, shouldn't be an issue going forward. If you can get a GM VIS report from a dealer service dept, that may help.
I replaced my water pump at 30k miles due to a seal leak. I now have 112k miles on the clock.
Old Feb 2, 2022 | 11:55 PM
HBsurfer's Avatar
HBsurfer
Having a new harmonic balancer is a very good thing. Like noted above, if the original balancer failed, it could damage the steering rack. Nothing to worry about now that they have been replaced. My 2007 is the most reliable car I have ever owned (after replacing the balancer)
Buy it and add another 100,000 miles to it.
Old Feb 3, 2022 | 10:36 AM
C6ToGo's Avatar
C6ToGo
Service interval for trans fluid change is 100k for normal service and 50k for severe service (city driving in 90 deg+, hills, performance driving). No mention of years.
So should be ok...I would change it soon after purchase.
Old Feb 3, 2022 | 10:44 AM
cmking26's Avatar
cmking26
None of that would bother me, as long as the work was done right and none of it is leaking. If the car is nice and appears taken care of go for it.
Old Feb 3, 2022 | 12:28 PM
PushrodV8's Avatar
PushrodV8
SamR, I have same year, 88k miles. Mine has had similar repairs, not to worry. I'd consider transmission maintenance, I noticed the difference right away.
Best money I spent on the car when I got it was new tires and alignment, like new car!
Join the club, good times in a fun car!
Old Feb 3, 2022 | 07:04 PM
nrl073's Avatar
nrl073
I have a 2007 with 103k miles. It has had the harmonic balancer and water pump replaced recently. The transmission was slipping and the dealer changed the fluid. That was at 90k miles.
Old Feb 5, 2022 | 12:39 AM
65 Drivr's Avatar
65 Drivr
If it's an automatic make sure the transmission upshifts smoothly in the lower gears.
The other issues you mentioned should be ok as long as done correctly as previously stated.
To 2007 corvette
