Bouncing Parasitic Draw
Old Feb 17, 2022 | 12:00 PM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
Default Bouncing Parasitic Draw
I replaced my old battery and decided to test for parasitic draw when dropping the new battery in. I'm seeing some odd behavior and wanted to know what the experts thought.
It stays in the low 30mA range, which should be normal, but it randomly spikes up to the 60mA range.
Video says it all, is there something else I should be looking into? Do I just have a bad connection from the multimeter to the car? Is the car looking for keys every 10 seconds causing the spike? Is there a security LED or pulse somewhere that could be causing this?
I'm more or less just looking to confirm whether this is normal or something I need to track down.
Full link:
https://youtube.com/shorts/OKZb30z2rrY?feature=share
Old Feb 17, 2022 | 02:51 PM
wjnjr's Avatar
wjnjr
Good question
Old Feb 17, 2022 | 04:07 PM
4SUMERZ's Avatar
4SUMERZ
You can try to remove the onstar fuse and try the test again to see if the reading steadies out. Try a test with your key fob not close to the car. It's not a serious draw, but a reading of less than 3 milliamps would be considered satisfatory.
Old Feb 17, 2022 | 04:11 PM
Vette_DD's Avatar
Vette_DD
Do you have an active OnStar?
Old Feb 17, 2022 | 06:02 PM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
I'll look up which fuse that is and give it a shot. I have a 2011 and was reading bluetooth and OnStar are powered through the same fuse but I don't use Bluetooth for anything since I have an aftermarket stereo now. I also disconnected my sub to see if that made a difference and it only dropped 1 or 2 mA so I don't think the new stereo is causing this.
Plugged in, yes, but I don't subscribe.
Old Feb 17, 2022 | 06:08 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
shut the car off, let the car sit for about 30 to 45 minutes before doing your test.
Old Feb 20, 2022 | 07:58 AM
Ep1429's Avatar
Ep1429
My C6 pulses the lights on the door’s locking **** when the security is engaged.
Old Feb 21, 2022 | 10:10 AM
cmonkey713's Avatar
cmonkey713
All systems must be in "Sleep" mode before doing the parasitic draw test. It is even better is the car sits overnight before doing the test just to make sure everything is in sleep mode.
Old Feb 21, 2022 | 10:38 AM
FatsWaller's Avatar
FatsWaller
I'm pretty sure the C6 doesn't have an external proximity sensor, so the external location of the fob shouldn't matter. You need to press an unlock button or pad on the car, or a button on the fob to initiate any kind of communication. Some cars do have a proximity sensor, like our CrossTrek. It actually turns on the interior lights when you get close to the car. Might was well remove the Onstar fuse in any case if 3G networks are disappearing.
To Bouncing Parasitic Draw
