I have a defective EBCM and am going to try and purchase one from a C6 Corvette that will be identified as known working. The only problem that I am running into is identifying the correct part numbers that will work with my 2007 Z06. Can anyone verify that all of these numbers will work on my 2007 Z06? (the list is very long and that is the reason for my hesitation) The numbers that I have seen so far are as follows: (I'm mainly interested in the 15141437 as there is one for sale right now on Ebay for $250 that I want to purchase, but I would like some verification first)
15858645 - This is what I pulled off of my car
15141437
89060341
89060303
89060304
89060305
15255614
15141437
15220716
15255614
15141447
25847888
25847891
15220712
15141333
Thanks for the suggestion C6ToGo, I actually spoke with a couple of the repair places and they said that the error codes that I have will not be corrected by the repairs that they do. They really only fix the corrosion problems that occur, and they look for cold solder joints. The codes that I am getting they said are probably an issue with a failing component which they do not address. I think I'm going to try the one off Ebay, and then I will run it to my Chevy dealer and have him set the Vin on it so it will work with my ABS system.
15141437
89060341
89060303
89060304
89060305
15255614
15141437
15220716
15255614
15141447
25847888
25847891
15220712
15141333
(long list huh)
James
Just to let those know that may be interested in the cross compatibility of the part numbers on this EBCM Part number 15141437 is a valid replacement for part number 15858645. I just replaced the 15858645 EBCM on my 2007 Z06 with the 15141437 EBCM and it worked fine. I didn't have to have anything programmed, I just installed the EBCM and pumg and ran the Autobleed on my scan tool as well as did a manual bleed on my brakes and all of the error codes are gone and I have an ABS system again. Whew, the ABS system can be a complete pain in the rear to have to deal with.
