C6 squeal
Old Mar 12, 2022 | 10:25 AM
c6crow's Avatar
c6crow
4th Gear
Default C6 squeal
I can’t figure out what’s causing this I took the belts off did the same thing chevy is saying torque tube
File Type: mov
Old Mar 12, 2022 | 10:54 AM
Tim81's Avatar
Tim81
I had a similar noise with my 06 and it ended up being the balancer.
Old Mar 12, 2022 | 10:57 AM
c6crow's Avatar
c6crow
4th Gear
Even with the belts off?
Old Mar 12, 2022 | 12:27 PM
farmington's Avatar
farmington
Video still had belts on.
Old Mar 12, 2022 | 12:50 PM
c6crow's Avatar
c6crow
4th Gear
I didn’t make a new video
Old Mar 12, 2022 | 04:53 PM
hydrasport's Avatar
hydrasport
Mine had a similar noise but it ended up being the alternator clutch. Only automatics have that clutch setup I think. But you said you removed the belt and it didn't eliminate the noise? Possibly worth looking at the balancer to see if the outer ring has moved back and is touching the timing chain housing.
To C6 squeal
