Oil pressure problem
Mirror and some contortion will allow you to replace it without having to remove the intake manifold.
As for radiator fluid change, chances are, had air in the system still by not putting a vacuum on the tank to dry the last of it out, and why it was reading high until the system purged the last of the air out of the system.
Here is the location of the radiator temp sensor, and with air in the lines, where the air will be trapped in the heads to cause the temp to read high on the sensor.
As for wet sump motor, oil pressure over 30 at idle,and would just call it good enough as is. GM states that lower is fine, but like to use the 30lbs at idle with hot oil the bench ok mark isntead. Lower than this and the sensor good, then it time to find the motor parts wear that is causing the lower pressure instead.
And for the Love of Christ, don't hack a hole in the cowling to change the oil pressure sensor out that way,
