Gas
Old Mar 16, 2022 | 05:35 PM
oldrunner's Avatar
oldrunner
2nd Gear
Default Gas
I have a 2012 Grand Sport, the LS3 engine.
I can get 92 octane gas with no alcohol or 93 octane gas with 10% alcohol.
Which would you use and why?
Old Mar 16, 2022 | 05:40 PM
Iceaxe's Avatar
Iceaxe
I believe 91 Octane is required for all LS3 Corvettes, so which is cheaper? All things being equal their is more energy in pure gas.
Old Mar 16, 2022 | 05:52 PM
Vette_DD's Avatar
Vette_DD
2012 owner's manual, page 9-49:
For best performance, use premium
unleaded gasoline with a posted
octane rating of 93.
Old Mar 16, 2022 | 10:14 PM
FatsWaller's Avatar
FatsWaller
To be fair, what the 2012 owner's manual actually states is
"If the vehicle has the 6.2L V8 engine
(VIN Code W), use premium
octane rating of 91 or higher."
(then some comments about using 87 Octane)
(VIN Code T) or the 7.0L V8 engine
(VIN Code E), use premium
octane rating of 93."
If your engine actually needs 93 octane to prevent detonation, then you should use it. If your ECU doesn't need to pull timing to prevent detonation when using 92 octane, then using 93 is a waste of money, and because it's got 10% ethanol, you'll likely get about 5% worse gas mileage. Ethanol has only about 50% the heat content of gasoline, gallon for gallon. The same argument holds for 91 octane. If you don't need it, it's a waste of money.
Old Mar 17, 2022 | 03:32 PM
Silvio61's Avatar
Silvio61
I’ve used Amoco gold in all my Vettes. 93 octane never a problem. Available still at BP stations. It’s the only gas I use.
Old Mar 18, 2022 | 02:56 AM
Holster Maker's Avatar
Holster Maker
The non alcohol choice.
Corn in the gas causes a bunch of problems.
To Gas
