Replace shocks
Old Mar 28, 2022 | 07:29 PM
edszo6's Avatar
edszo6
Cruising
Default Replace shocks
I have a 2009 corvette with soft ride shocks. I want to replace them,can I replace them with ZO6 shocks and sway bars. Or should I go coil overs? Any help would be awesome.Soft ride sucks,to soft for me.
Old Mar 28, 2022 | 07:59 PM
SixAddict's Avatar
SixAddict
I switched my 09 out to Z06 shocks and sways. Big difference.
Old Mar 28, 2022 | 10:11 PM
Iceaxe's Avatar
Iceaxe
Spend the extra $100 and get Bilsteins if you're going the shocks and swaybars route. There is a reason Bilstein are popular with the Z06 crowd when they replace shocks.
Either way, you won't be sorry with shocks and sways, they change the base ride greatly for the better. No more wallowing through the corners like your dad's Cadillac, but nice and flat like a sports car should.
Old Mar 28, 2022 | 10:54 PM
Patsgarage's Avatar
Patsgarage
Wouldn't you have to replace the fiberglass leaf spring as well ? I don't think the base and Z06 used the same ones.
Old Mar 29, 2022 | 02:51 AM
Dano523's Avatar
Dano523
DRM shocks, swap the front trans spring from a FE1 to FE3 to solve the over nose dive during breaking into the corners, then swap out the sways to Z51 sway bars. Also, change out the rubber bushing in the car, to poly bushings.
This will get you up to Z51 set up, but will flatter in the corners due the stiffer dampening of the DRM shocks
Trying to go Z06 set up, will not end well on the base cars, since you don't have the wide body panels need to get the needed wider rims and tires on the car for more tire traction to make that set up work well, short of running R compound tires on the street.
Hence may feel like you can corner better on parking lot tracks that are smooth at lower speeds (car dam near pan'd), but get into the rougher tarmac at speeds, and the car will be all over the road instead.
Old Mar 29, 2022 | 09:55 AM
Orion2011's Avatar
Orion2011
Put Bilstein's on my Base C6. Huge difference! If it's a street car don't worry about making the suspension stiffer, it's not needed on the street.
Old Mar 29, 2022 | 02:36 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
I put Bilstein's on my C6 GS as well. Very high quality. The ride quality improved slightly but was most noticeable in the turns - much more planted over the OEM shocks.
Old Mar 29, 2022 | 03:16 PM
Dutch08's Avatar
Dutch08
Finally, someone that feels the way I do about how a sports car should ride. I have a 2005 Z51 MN6, if that makes a difference, and I switched to Bilstein "B8" shocks. The ride is still too soft for me but getting closer to what I like.
Hope this helps a little ...
Old Mar 29, 2022 | 03:33 PM
Iceaxe's Avatar
Iceaxe
With B8's you can feel a quarter on the road, with DRM's you can tell if it's heads or tails.
Old Mar 29, 2022 | 09:12 PM
Nokones's Avatar
Nokones
Which Bilstein shock did you put on your car? The B4s or the B6s? The Koni Yellow single or doubles would have been a better shock for the street and some spirited driving or autocrossing.
Old Mar 29, 2022 | 10:33 PM
Iceaxe's Avatar
Iceaxe
The B6 and B8 Bilstins will both fit any C6. The biggest difference is the B8's are about 20% stiffer. The only actual difference between the two shocks is valving.
B6 are recommended for "premium street performance".
B8 are recommended for premium street perforance, autocross, track "and" for cars that have been lowered.
The reason you want to run B8's on a lowered car is they will not bottom out as easily as the B6 because they are stiffer.
Bottom line, on a C6 they are the exact same shock with different valving. The B8 will give you improved performance at the cost of some ride quality.
If you want to go stiffer than B8's you want the Bilstien DRM's.
Adding polyurethane bushings to any of the above mentioned shocks will stiffen the ride further.
I've driven a C6 with all three versions at one time or other. I'm one of those guys that will sacrifice a little comfort for improved handling. My C6 is currently running DRM's and they are stiff. If I was only driving on the street I'd go with the B8's.
Hope that helps.
Old Mar 29, 2022 | 11:40 PM
GettnBetter's Avatar
GettnBetter
DRM's are fantastic! They are essentially the same as Bilstein Sports with more jounce (upward control, I could be wrong, the exact valving I'm not sure of). In any event, on my C6Z and C5 /w Z51 they are amazing. The C6Z stock shocks are rather flighty in comparison.
Old Mar 29, 2022 | 11:54 PM
vezePilot's Avatar
vezePilot
I have to agree that for a Base C6, the DRM/Bilsteins and the Z51 Bars are a great combination. I have looked for an FE3 Front Composite Spring on eBay. I'm not ready to spend for a new one, because I don't have plans to Track the car this year.
And the ride is now stiff enough for my needs. I don't think I would enjoy replacing all of the bushings with stiffer polyurethane or delrin.
Also, changing out the stock Mag ride shocks for the DRMs was relatively easy. I have worked with coil-overs before, and they are simply much more difficult and dangerous for a shadetree/driveway modification enthusiast.
If you shop for a used FE3 Front Spring, Dano can provide the exact part number that you need. Without the correct number, it might be very easy to waste your money.
Old Mar 30, 2022 | 12:51 AM
Dano523's Avatar
Dano523
Two different FE3 front trans springs, and it comes down to if the car is M6, or A6, since the A6 Fe3 spring is slightly stiffer due to the added weight of the auto trans.
Again, the reason for the slightly stiffer front spring (fe1 to Fe3) is if you are breaking hard coming into a corner, Fe1 spring will weight transfer too much to the front end to dive it too much. If all your doing it gliding country road curves, then Fe1 spring may be better for you instead.
And again, if the suspension is too firm for the tire grip in play, will not end well at speed.
Here is the proving ground corner for suspension set up, where the car needs to hold the banked concrete inner line (smooth it is not so you need wheel travel as well) for the faster way around this corner, and if the suspension is too tight for tire grip in play in the chatter, stand no chance in hell holding that line at speed, much less not ending up in the guard rail as you slide out of the banked line and up the not banked asphalt side instead.
Old Mar 30, 2022 | 08:25 AM
rharper's Avatar
rharper
I have a base suspension car, and did as Dano523 and others said. DRM shocks, Z51 front spring and Z51 sway bars. I didn't do poly bushings, but the handling is MUCH improved over stock. Going by memory Shocks were ~450. Pre-owned spring ~120. Sways from Cultrag ~275. Installed myself. Front spring is a PIA, other parts easy.
Old Mar 30, 2022 | 08:35 AM
Nokones's Avatar
Nokones
On my 13 manual tranny Grand Sport I put on custom valved double adjustable JRi shocks because I autocross the car.
To Replace shocks
