Wobble Wobble
Old Apr 11, 2022 | 07:32 AM
blownbayou's Avatar
blownbayou
Default Wobble Wobble
So I have the wobble and trying to hold off until next year to change it while doing a cam..... I bought the car in Feb 2021 with 65k on the clock and it now has about 69k on the clock. Not driven daily as you can tell. Can I keep driving it occasionally until I can get the work done??? No belt squeak at all as of now. Figure if I hear get belt squeak. then I will shut it down or move up the install.
Your thoughts on this please
Old Apr 11, 2022 | 07:55 AM
jjfabs's Avatar
jjfabs
If you want to drive more than a short ride replace it now or shut it down. You don't want to be to far away from home if and when it fails. Personally I would fix it as soon as time permits
and since you don't seem to drive it all that much, put it in the garage and take your time on the repair.
Old Apr 11, 2022 | 09:07 AM
ClothSeats's Avatar
ClothSeats
The main danger is that once the elastic bond between the hub and pulley is totally broken, the pulley can walk back toward the engine front cover and wear a groove into it. If you want to run it for a while, it might be a good idea to crawl under there and periodically inspect the area between the pulley and the front cover. When you see that clearance starts to get smaller, that would be the time to stop driving and start fixing.
Old Apr 11, 2022 | 10:14 AM
blownbayou's Avatar
blownbayou
Video shows the wobble, but it is not as apparent.
File Type: mov
Old Apr 11, 2022 | 11:49 AM
SixAddict's Avatar
SixAddict
Thats not bad at all. Mine was about the same and I drove it like I stole it, still do. At 80k had cam work and other things done along with balancer, all is well now.
Old Apr 11, 2022 | 11:58 AM
rbwinston's Avatar
rbwinston
Not terrible but I would keep an eye on it and probably keep the rev's down. Mine looked about like that and I did change it. You're probably fine for a little longer.
Old Apr 11, 2022 | 01:25 PM
blownbayou's Avatar
blownbayou
Appreciate the replies..... Feel a little better trying to extend it to next year when I do the cam.
Old Apr 11, 2022 | 01:52 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Wobble
. Crawling under is not that easy. Take a measurement from the back of the steering rack cylinder to the balancer edge and keep an eye on it from the top.
Old Apr 11, 2022 | 04:05 PM
Vetteguy2791's Avatar
Vetteguy2791
When i bought mine, it didnt wobble as much. Last week mine was wobbling like that and I replaced it. most likely will get progressively worse.
Old Apr 11, 2022 | 04:08 PM
farmington's Avatar
farmington
Get your parts so you will have them when you need them. Look for a shop to do it. Be ready when the time comes to do the swap.
Old Apr 11, 2022 | 09:43 PM
Pander's Avatar
Pander
Going to play devils advocate to running it, when I bought a C6 last year, I was in the same predicament as you and posted the exact same question. My wobble was very slight like yours and there were no noises and it did not effect performance. Most said to just run it, and they probably would have been right for most Corvettes, but knowing my luck I decided to park it until two months later when I was able to get the harmonic balancer changed and I'm glad I went the cautious route and parked it, because the mechanic showed me the rubber between the inner and outer HB was half torn already and could have completely separated while driving:
and here's the new ATI balancer with ARP bolt:
Old Apr 11, 2022 | 10:15 PM
jjfabs's Avatar
jjfabs
Like I said blown bayou........
Old Apr 12, 2022 | 07:25 AM
Diamonddave60's Avatar
Diamonddave60
Drive it
To Wobble Wobble
