Aluminum Gas Pedal
Old 04-18-2022, 11:17 AM
halfatruck
halfatruck's Avatar
Default Aluminum Gas Pedal
Anyone have a clue what site sells this replacement pedal?
Old 04-18-2022, 11:37 AM
gdmoore01
gdmoore01's Avatar
Looks like Corvette Central used to sell them, but are now discontinued. eBay as well. Plenty of other aluminum styles available.
Good luck on your search & maybe someone on the forum can turn one up for you.
GD
Old 04-18-2022, 03:47 PM
lilcuda
lilcuda's Avatar
Here’s some other options.
https://www.eliteengineeringusa.com/...num-gas-pedal/
cmonkey713 (04-18-2022)
Old 04-18-2022, 06:27 PM
Let It Ride
Let It Ride's Avatar
If I'm not mistaken isn't that the oem gas pedal that comes on a C6. I had 3 C6's and that's what I remember. Can't you just go to the dealer?
Old 04-18-2022, 07:22 PM
Trebor
Trebor's Avatar
I had good luck with SRP racing pedals that Installed on my 5th gen Camaro. Nice quality. They have them for the C6 Vette.
https://www.srpracing.com/pd-c6-corv...ing-pedals.cfm
Old 04-18-2022, 07:39 PM
halfatruck
halfatruck's Avatar
never seen one like this on a C6, although it has the OEM look, unlike the Elite pedals
Old 04-18-2022, 07:52 PM
Iceaxe
Iceaxe's Avatar
Received 2,610 Likes on 1,395 Posts
Nope, it's not OEM. The factory gas pedal is a plastic POS that looks like it was originally installed in a 74 Vega.
I'm running the Elite pedal if anyone cares.
Old 04-18-2022, 08:32 PM
ls1121
Support Corvetteforum!
ls1121's Avatar
St. Jude Donor '14-'15
Looks just like mine. I bought it with the dead pedal together. If I can find my receipt I'll tell you who I bought it from. OK I bought them from CorvetteMods back in April of 2013.
Old 04-18-2022, 11:14 PM
Let It Ride
Yup you just refreshed my memory. I was thinking of something else.
Old 04-19-2022, 11:24 AM
wjnjr
wjnjr's Avatar
SRP Pedals. Very grippy with a good look. Gas pedal makes it easier to heel & toe. The heights of the clutch and gas pedals are adjustable to driver preference. You find these on autocross/track/wheel to wheel race cars. They work nice on the street & drag strip too.
Old 04-19-2022, 11:42 AM
SixAddict
SixAddict's Avatar
Received 1,123 Likes on 768 Posts
https://www.ultimatepedals.com/.
js78 (04-20-2022)
Old 04-20-2022, 11:57 AM
Dano523
Dano523's Avatar
Received 3,049 Likes on 2,194 Posts
FYI, but on the elite pedal, why it does not come with a nylon barrel shim to keep it tight, still have no clue.
As for standard or heal toe, go with the heal/toe if you are doing any kind of road course use. Hence dropping into 2 from 5 during hard braking for end of straight corner, will need to blip the throttle to get a clean shift into second, so you can come off the clutch on the way out of the apex,
Note, I don't do engine braking, so brakes all they way to the apex to keep the front end weight transferred, then back of the throttle on the way out to force the back end to drive the front end inwards to hold the line.
Old 04-20-2022, 03:26 PM
GS-2013
GS-2013's Avatar
To those that have the Elite pedal...how difficult was the install? Can you give me an idea what is involved? I like the idea of the heel toe pedal.
Old 04-20-2022, 05:13 PM
ls1121
ls1121's Avatar
I would suggest that you remove the pedal assembly and do the replacement on a bench. Working in that small space was too daunting for me.
Old 04-20-2022, 05:37 PM
Dano523
Dano523's Avatar
Very easy, since you remove the pedal assembly from the car, then remove the old pedal, install the new pedal with home made barrel shim (could just use a bic pen case), then reinstall the pedal assembly back in the car.
The top section of the pedal is a clip in, so you just need to pull the connector, and remove the bottom nuts to pull it from the car.
https://www.corvettemods.com/C6-Corv...ly_p_8261.html
Old 04-20-2022, 06:14 PM
Iceaxe
Iceaxe's Avatar
Easy 20 minute job. I'm not sure what the shim is Dano is adding. My pedal came with a spring that slides over the Allen bolt to keep everything tight and in place. This second spring might be Elites solution to the shim Dano added, or not...
Here is the pedal install video for anyone interested. It also shows the second spring I mentioned.
Old 04-20-2022, 09:33 PM
Solaris
Solaris's Avatar
It's not too hard. There's a pin pressed in the original pedal that you have to pull out with vice grips. May not be the most fun time in such a tight space. Then the Elite pedal bolts in. This was the first thing I did to my GS.
To Aluminum Gas Pedal
Old 04-20-2022, 09:49 PM
vetteJPJ
vetteJPJ's Avatar
These look good. But which has the best grip? My foot slips off clutch if my shoes get wet. Sometimes that's scary.
Old 04-25-2022, 12:25 PM
KnightmareLS1
KnightmareLS1's Avatar
Just bought these from your suggestion, they look awesome but you had me at ADJUSTABLE. Thanks!
Old 04-25-2022, 03:08 PM
wjnjr
wjnjr's Avatar
Yeah, the pedals are overlays, so you can change their height using spacers if necessary to get to your preferred driving position - seat vs pedals vs steering wheel vs shifter. It just gives you another degree of adjustability along with the seat and steering wheel. On my car I raised the clutch pedal about 1" and the gas pedal 1/8" to make heel & toe easier. I used spacers made by Bondura Performance engineering.
Quick Reply: Aluminum Gas Pedal
