How to clean C6 door touchpad circuits
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
The doors on my 08 convertible were getting harder to open. I removed the touchpads from the doors and sprayed them with a little electric contact cleaner and wiped them off. I then put a very light coating of dielectric grease on both the tabs and the printed circuit board for each door and put everything back together. The doors open better, but I’m still not satisfied. What’s the best thing to use to clean the contacts.
![](/forums/images/ranks/4k-5k.gif)
Pencil eraser.
The following 2 users liked this post by madsonp:
Deconblue (05-12-2022),
NBVette_Canada (05-12-2022)
![](/forums/images/ranks/5k-6k.gif)
I used 400 grit sand paper and have heard a pencil eraser works weel too
Diamonddave60 (05-13-2022)
You don't really want to put dielectric grease on electrical contacts. It's non-conductive so sort of defeats the purpose of trying to get a better connection.
The following 3 users liked this post by ProCycle:
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_air_force.png)
Received 4,550 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
There cheap enough to replace them, and I hear there not being made any longer.
Try E-Bay.
Try E-Bay.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
![](/forums/images/ranks/3k-4k.gif)
St. Jude Donor '09-'10-'11,'13-'14-'15-'16-'17-'18-'19-'20-'21,'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/StJude10.jpg)
GMGENUINEPARTS.COM HAS THEM. Just ordered and replaced both on my 2008. IIRC, somewhere in the neighborhood for $22 each. GM part # 22751230
![](/forums/images/ranks/1k-2k.gif)
I have a 08 with similar issues with the door opener pads about 2 years ago. I followed the recommendations for cleaning the contacts and had good results. It wasn't long before the issues returned. This happened twice. Turns out that the openers are so cheap to buy new, I was able to replace both pads with new ones for less than $40 bucks.
![](/forums/images/ranks/7k-10k.gif)
Received 3,098 Likes
2021 C6 of the Year Finalist - Modified
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Here is a link to a new door latch release switch (touchpad)
Left and right are interchangeable
$23.95 with free shipping
https://www.ebay.com/itm/363259541349
gpruitt54 (05-13-2022)
Received 1,847 Likes
I’m not buying the dielectric grease argument. You could argue it out with these guys, who are in the business to know: https://www.nyelubricants.com/myth-g...h-conductivity
In part, their article states
"The results of these tests prove that there is no difference in contact resistance between lubricated and unlubricated connectors. Grease fills in the microscopic valleys of the contact surface and is squeezed out of the asperities, allowing the current to flow and preventing oxidation from occurring. While there is no difference in conductivity, the water resistance test proves that dielectric grease offers protection that unlubricated connectors cannot. In conductive environments, such as water, unlubricated connectors experience current leakage which can result in short circuits. Dielectric grease insulates connectors to prevent current leakage from occurring."
I used this stuff on the underseat connectors when I fixed the air bag light problem, on all the LED lamp replacements, and on the big connectors on the BCM. No problems whatever with connectivity.
Deconblue (05-18-2022)
Had the same problem last year with my 05. Used very fine steel wool to lightly polish the contacts, reinstalled and have worked perfectly since. As a backup measure, I bought a set of replacement pads, but they are sitting in my toolbox in case they are needed. So far, so good! Good luck! It is a quick and easy maintenance item.
gpruitt54 (05-16-2022)
