Corvette C6 Convertable
Old May 15, 2022 | 02:27 PM
CorvetteC6C$'s Avatar
CorvetteC6C$
2nd Gear
Default Corvette C6 Convertable
Hi Members',
I am new to Corvette Forum and wish you all a Great Sunday. My problem is that my 2007 C6 (37,400 miles) is too low in the front , My Deflectors keep scraping the ground when I go up m Driveway. Does anyone know how to adjust the Front Ride Height? I see Body Lowering Bolt kits & Body Lowering Bushings. Does any Company sell Front End Raising Parts?
Any Help or Suggestions would be Greatly Appreciated>
Thank You,
CorvetteC6C$
Old May 15, 2022 | 02:32 PM
LightningBrett's Avatar
LightningBrett
There are front and rear bolts on your car that are used to raise or lower it. The springs rest on them. Here is a chair to go with your converTABLE.
Old May 15, 2022 | 05:10 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Convertible!!!!!!!!!
Old May 15, 2022 | 05:20 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
Jack your car up letting the wheels hang down, then the bolt at the end of the leaf spring screw it down, that should raise you car up approx. 1". Its not very hard, just take your time and keep them even side to side, take a measurement before and after done to see the difference.
Old May 16, 2022 | 10:32 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Make sure to have the car aligned after changing the ride height but wait until the suspension has settled in.
To Corvette C6 Convertable
