Noisy driver's window
Old May 27, 2022 | 07:39 PM
vetteJPJ's Avatar
vetteJPJ
Default Noisy driver's window
When closing the driver's side window there is a crackling sound when it reaches the fully closed position. I'm afraid the regulator is about to bite the dust. Is there anything else that could cause this sound? It indexes just fine and is totally quiet when opening.
Old May 27, 2022 | 11:32 PM
vetteJPJ's Avatar
vetteJPJ
OK Then. I guess I'll just order a new regulator just in case, It's my daily driver so I can't have it waiting for parts.
Old May 28, 2022 | 11:46 AM
74plb's Avatar
74plb
I put up with a noisy regulator on the drivers side for a couple of months. It failed in the down position of course. I found a nib regulator on the forum here.
Not too bad of a job, only took an hour and a half or so to R&R it.
After putting on the door panel I discovered that the door has to be shut to index the window. Didn't take too long to figure that out
74Plb
Old May 29, 2022 | 10:46 PM
vetteJPJ's Avatar
vetteJPJ
Thanks for the info.
To Noisy driver's window
