Driver side window regulator/door release switch problems
Old May 27, 2022 | 08:56 PM
Little_Red_'05's Avatar
Little_Red_'05
2nd Gear
Default Driver side window regulator/door release switch problems
The driver side window on my 2005 recently started acting up. Sometimes when I close my door, the window doesn't return to the "up" position. When this happens, the handle button doesn't release the door, so I have to use the manual release or roll down the window to open the door from the outside. It usually takes a few attempts to get the window to actually close, but once it does, I can open and shut the door repeatedly with no issues. To be clear, the door does fully close. Has anyone else had this particular gremlin? Since the door won't open from the inside when it's happening, I'm hoping it's just the door release switch... But could it be that the window regulator is going bad, causing an intermittent circuit break for the switch?
