Bad battery
Old May 28, 2022 | 10:18 AM
oupomdad's Avatar
oupomdad
4th Gear
Default Bad battery
What to do in a 2005, when your battery goes completely dead ( shorted) and your vet won’t even jump start?
Old May 28, 2022 | 10:32 AM
Carl Timonen's Avatar
Carl Timonen
Have someone delivery a battery to you and r&r.
Old May 28, 2022 | 10:34 AM
BadAV's Avatar
BadAV
Open the hatch with the key, pull the door release cable, open the door, pull the hood release cable, replace battery. If you can't do that, jack front of car up, hook jumper cable to starter positive terminal, ground to a ground on the body, open door, pull hood release, open hood, replace battery.
Old May 28, 2022 | 10:50 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Uhh....replace the battery If you're locked out, open the trunk, pull the cable on the left side that releases the driver side door. Spring for an Optima Red Top size 25 replacement battery & be sure to use a battery tender if you're not already using one. The Red Top 25 will fit perfectly in an '05.
Old May 28, 2022 | 05:26 PM
sramzzz's Avatar
sramzzz
My smart *** reply is don’t jump a shorted battery and simply replace it. Others have chimed in on how to get into the car.
To Bad battery
