ABS and scanner question
Old Jun 8, 2022 | 12:00 AM
psaboic's Avatar
psaboic
Default ABS and scanner question
Hi folks,
I haven't been on here much over the last couple years as the 2005 has not had any issues at all.......until today. I left for work today and as I was turning left at an intersection, I felt the car pull a bit to the left and at the same time I got a "Service Active Handling" message on the DTC. I turned the traction control off with the console button for a few minutes and then turned it back on with no further issues. Car sat at work for 8 hours, and as I was leaving for home I got the big three on the DTC (Service Traction Control, Service Active Handling and Service ABS) after moving the car about 50 feet. I cleared them off the DTC but the ABS light and Traction Control lights stayed on.
I'm going to pull the wheels this weekend and clean and check the wheel speed sensor connections, but after that if the problem persists, I want to scan the car to find what the specific issue is without just throwing parts at it. I know this issue can be caused by anything from a loose connection all the way up a bad EBCM. Soooo, without spending hundreds of dollars or getting a Tech 2 clone that I will probably rarely if ever use, is there a scan tool that will be able to point me in the right direction to fix this issue. If not, does anyone who has had this issue have a good step by step troubleshooting guide they could point me to so I can find the fault and fix it. Many thanks!!
Old Jun 8, 2022 | 09:43 AM
C6ToGo's Avatar
C6ToGo
Before you do anything, I would scan for DTC codes. You could go to Autozone, but it might be time for you to own a tool. Make sure it is capable of scanning ABS and SRS (airbag) codes.
In addition to my Tech 2, I like my Autel unit for all my vehicles. Less than 90 bucks.
Amazon Amazon
Old Jun 21, 2022 | 03:32 PM
C6VetteLover's Avatar
C6VetteLover
Originally Posted by psaboic
Hi folks,
You will need a scan tool that can not only read ABS codes but also displays live data. Several good tools on the market for under $500 that will likely save you headache in the future. I personally have a Launch X431 V pro
Amazon Amazon
I love it.
That being said this would also be good for a budget scan tool
Amazon Amazon
To ABS and scanner question
