DSX e85 kit removal question
Next step is to remove the harness - it should be plugged into one of the coil's plugs (usually the one far right). You want to unplug the DSX harness and plug the coil's plug back into the coil. A black/grey wire is going from the DSX kit harness to the ECU. Don’t pull on it as you might damage some other connectors on your computers. I would recommend cutting the wire close to the connector, protect the end and tuck it somewhere. The next guy might appreciate having that available or you could use it may you ever change your mind.
Then, you have to plug the car’s fuel line to the fuel rail and you’re done. I took a quick picture on my car to show you, circled in red. Don’t look for the same harness as you, it is different on my car. The hardware should be identical though.
You have to be aware of the software side - chances are your ECU is setup to read the ethanol content from the sensor. I would highly recommend taking it to a tuner first so they update your calibration to deactivate the flex fuel feature (make sure to first have around 10/15% ethanol max in your tank).
Then you should be all set
