Push rod ordering
Jun 20, 2022 | 09:06 PM
Push rod ordering
New heads and lifters, pushrod checker will be here tomorrow. I assume with these Johnson lifters it will be more than one size I will need.
who do I order a custom set from?
Jun 21, 2022 | 01:03 AM
They say hey measure each time you implement a custom setup, but I'd be surprised if vendors TSP or BTR don't know typical lengths...
EDIT
Never mind you already have checker handled, however vendors are good
Jun 21, 2022 | 10:17 AM
You have a little leeway with pushrod length. Measure the 4 corners and compare the numbers.
Jun 22, 2022 | 12:56 PM
Did already mention pushrod checker on the way, don't believe this is a variable with hydraulic lifters, OP could you clarify
Jun 22, 2022 | 01:47 PM
FED heads with Johnson dog link lifters .
Jun 23, 2022 | 12:12 AM
Sorry I don't know the setup well, however, the vendor that you went too will know what too do with your pushrods, I can't imagine they wouldn't spec all the same, but I have no idea
Jun 23, 2022 | 08:57 AM
Best way to determine push rod length needed is to measure using a pushrod length checker. I use the checker and then verify with a 2nd method such as counting the # of turns of the torque wrench it takes when torqueing the rocker arms.
Jun 25, 2022 | 02:02 AM
OP sounds like that answers your question...using the checker to measure your lengths..
