Dyno Results
its a 2005, Z51, M6. 17K miles.
Mods are:- TSP ported LS3 heads
- Gwatney ported OEM LS3 intake
- Gwatney ported OEM LS2 throttle body
- Cam Motion Titan 2 cam 222/230 113 +3
- Comp Cams 1.8 steel roller rockers (.630/.621)
- Johnson 2110 lifters
- LS3/Z06 aFe Magnum FORCE Stage-2 Intake
- LS3 MAF sensor - blade style
- "Vette-Air" cold Air intake scoop
- Std. speed ATI harmonic balancer
- ARH 1 7/8 headers with cats
- C6 Grand Sport MPP Mufflers with NPP in a Box
- C5r timing chain
- C6 Z06 brakes
MRR 755 Wheels - C7 ZR1 Style
- Front - 18x9.5, offset +56, 275/35-18
- Rear - 19x11, offset +79, 305/30-19
The car was throughly heat soak before being dynoed. I had spent 2 hours driving 67 miles in 95 degree weather to get to dyno, the last hour was stop and go driving. Tuner said it would have made 10 more HP if it wasn't heat soaked.
The car made 471 RWHP and 445 torque. 400 ft/lbs from 2800 to redline and I guess 300 ft/lbs from 2K.
That's for the advise while I was planning my build.
This was a budget build, $5K in total parts including the headers and some specialty labor.
The TSP ported/polished LS3 heads with Gwatney ported/rod-modded LS3 intake and ported OEM throttle body combined with the 1 7/8 headers got a 97% dynamic efficiency on the dyno. Tuner said that was huge.
The tuner said my LS2 throttle body was likely the limiting factor on more power. He suggested a 102 TB, colder day, and more aggressive tune would get me 500 HP. That seems optimistic.
The small cam is key to the torque. It can be driven in almost any gear from 1200 RPM or so to redline without ill effects.
I found 4" of vacuum right behind the throttle body on that Heartbeat blown LS3, but that was at 660+ rwhp. Also drilled and tapped a hole between the throttle body and air filter. No vac there so the CAI wasn't the culprit.
And yeah, I taped a tennis shoe to the dash and set the vac gauge in the shoe. Ran a line out the widow and under the hood. Pretty much full blown redneck.....but I is one. It worked. My son saw it and just shook his head.
My tuner said a cooler engine with maybe a little more aggressive AFR could get another 15 HP or so. He also said a larger throttle body would help, but the OEM LS3 intake doesn't port-match with a 102 TB so this might be a minimal gain.
This fall I will go back to the dyno on a cold day and see what a cool engine does in terms of power.
So Forum, what would another .0150 milling of the heads give? The downside to this is would require fly-cutting of the pistons.
However, fly-cutting and another milling of heads is easier/quicker than a cam change.
Also, I'm not wild about another cam as I really love my torque curve. From 1500 onward, it pulls hard. I really don't want a peaky cam that's hard to drive.
Thoughts anybody? Or should I just shut-up and like what I got :-)
Agree with motorhead on TB. Factory does not seem to be a bottle neck if 500 WHP is the goal. If really contemplating cam change, Spin's cam netted 62 WHP / 23 WTQ with excellent manners in my case. No low RPM issues at all. Drives like stock (until get into the throttle) with current tune and 4 degrees overlap. Very smooth.
Really like your setup. Looks like a proper NA build IMO.
Yes, TB is ported also.
SOP is very good.
This is my take also.
A bigger cam would be complicated. It would involve fly-cutting the pistons, removing the rack, etc. which is a big project. I currently zero margin for a bigger cam due to PTV issues
I know I'm being wishful. First 220 RWHP cost about $5K in parts.
Next 34 RWHP would likely cost another $5K. Very bad math!
