NPP Problem - 2009 Base
Old Jul 8, 2022 | 07:11 PM
colormegone2003's Avatar
colormegone2003
Cruising
Default NPP Problem - 2009 Base
2009 Base Corvette with NPP exhaust. I am the original owner.
After driving with exhaust closed for 20 to 30 minutes, the flaps will open on their own (at low speed) and will not close unless I shut off the car and restart.
Could it be the Vacuum Actuator or the Bi-Mode Exhaust Control Module?
I have checked all of the vacuum connections and everything seems to be in order. Where is the Bi-Mode Exhaust Control Module located? I want to check the connections on that.
I had a Mild to Wild controller/switch on the car and removed it as to narrow down the problem. When the flaps opened on their own, the M2W controller had no effect.
Removing it had no effect on the flaps opening under 3500 RPM's.
Looking for help to resolve the issue.
Old Jul 8, 2022 | 09:45 PM
farmington's Avatar
farmington
Pull the vac hoses off of your valves. Close the valve with your hand. Put a finger on the hose nipple. If the valve is good it will stay closed. If valves check ok, go to the module by the tail lights.
Old Jul 8, 2022 | 11:43 PM
FatsWaller's Avatar
FatsWaller
The most common failure is the vacuum solenoid. Sounds like yours is circling closer to the drain. It's located behind the passenger side taillights I believe and replacing it is DIY. And it's not that expensive. There's a few writeups on the forum on how to do it and probably some YouTube vids, so a Google search should find those.
Old Jul 9, 2022 | 06:11 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Anyone know the part number for the vacuum solenoid for a base 2013?
Old Jul 9, 2022 | 06:40 AM
vetteish's Avatar
vetteish
It’s the solenoid. Amazon has it so you get get it ASAP. Very easy install. Lots of videos.
Is used this one for ‘11 GS.
this is the Amazon description:
GM Genuine Parts 25794610 Engine Intake Manifold Tuning Vacuum Control Solenoid Valve
Old Jul 9, 2022 | 07:45 AM
colormegone2003
Cruising
Thanks to farmington and FatsWaller for the responses. I will try both ideas. I do know where the Vacuum Actuator is located. Still trying to find out where the Control Modular is located though.
Old Jul 9, 2022 | 10:07 AM
FatsWaller's Avatar
FatsWaller
It's called the Exhaust Tail Pipe Flow Valve Control Module.. If you look at the first post in this thread, there's a pic of the location. https://www.corvetteforum.com/forums...is-module.html BTW, I don't recall ever hearing about one of those failing, but like all electronics, I suppose it's possible.
Old Jul 9, 2022 | 11:40 AM
colormegone2003
Cruising
Dear FatsWaller ... thank you very much for the information.
Old Jul 9, 2022 | 11:53 AM
Dano523's Avatar
Dano523
Dude, when don't they fail, is the question instead.
Hence GM designed them backwards to sell more replacement parts, so when car is started, it powers up to allow allow the vacuum through it, and when you shut the car off (or Npp controlers kills the power to it for a few seconds to go into loud mode), it then powers down to close the vacuum through it instead.
So since it spends most of it time in an energized state to keep the gates closes when the motor is running, pretty much burns itself up in a few year isntead.
Old Jul 9, 2022 | 12:04 PM
FatsWaller's Avatar
FatsWaller
No argument that the solenoids fail, but the control module seems to last just fine.
Old Jul 10, 2022 | 02:45 PM
farmington's Avatar
farmington
A lot cheaper than the GM part
Old Jul 15, 2022 | 12:47 PM
colormegone2003
Cruising
Follow-up: I replaced the Vacuum Actuator and it fixed the problem.
Thanks to all for the information.
Cheers!
Old Jul 15, 2022 | 01:53 PM
FatsWaller's Avatar
FatsWaller
Cheers!
Actuator or solenoid? The actuators are attached to the mufflers.
Old Jul 15, 2022 | 03:44 PM
colormegone2003
Cruising
It was the Solenoid.
Old Jul 15, 2022 | 07:02 PM
Mike2013's Avatar
Mike2013
Is the solenoid valve located behind the rear lights on the right side?
Old Jul 15, 2022 | 07:59 PM
Dano523's Avatar
Dano523
https://www.corvetteforum.com/forums...any-ideas.html
Old Jul 15, 2022 | 08:05 PM
FatsWaller's Avatar
FatsWaller
passenger side = right side
no factory cars were right hand drive
“Behind the passenger side taillight, mounted on the bumper bar. Its under a waxy, rubbery cover.
Remove the inner passenger taillight and reach down to the bumper. You will feel the cover. It is underneath that cover.”
Old Jul 17, 2022 | 06:00 AM
vetteish's Avatar
vetteish
great news !
To NPP Problem - 2009 Base
