Corvette c6 electric problems
Old Jul 11, 2022 | 01:49 AM
OBM's Avatar
OBM
1st Gear
Default Corvette c6 electric problems
Hello
I have problems with my vehicle, corvette c6 LS2
It has a problem that when turning off the engine it does not cut the dash and radio contact.
I have to disconnect the battery
Sorry for my english
Old Jul 16, 2022 | 01:59 PM
cmonkey713's Avatar
cmonkey713
Sounds like to me the accessory portion of the starter switch button is not disconnecting as it should when turned off. I would replace the switch and see if that fixes the issue.
Old Jul 16, 2022 | 07:27 PM
Dano523's Avatar
Dano523
When you shut the motor down, need to open the door before the dash lights and other accessories like radio are powered down.
If you are opening the door and the accessories are not powering down (including the radio), best guess would be that someone put an after market radio in the car, and did not use the correct after market radio module adapter in the car. Hence radio is wired in to main constant power, and the accessory wire off the raadio, is back feeding the rest of the cars accessory wiring.
So on the correct after market radio module adapter, it gets the signal from the BCM when the door is opened like the other modules, to kill the power to the radio to put it into sleep mode as well. As for figuring out what after market radio adapter is needed, you can use Crutchfeilds web site to plug in your car and options, select any radio, and it will tell you which after market radio module adapters will work.
https://www.crutchfield.com/car/cars...r%2fmycar.aspx
And, as stated by the other post, make sure that the BCM is showing to be in the off position when you turn the car off, and not stuck in the ACC or run mode with motor off, by pushing and holding the bottom of the starter button too long instead.
Hence to kill the motor, should only take a quick touch at the bottom of the starter rocker button, and not having to hold it in for any time isntead.
To Corvette c6 electric problems
