C6 climate control not working
Old Jul 11, 2022 | 03:55 AM
Jehad Tamim's Avatar
Jehad Tamim
2nd Gear
Default C6 climate control not working
hello guys,
I have a new issue in my 07 C6 and looking for a solution if someone faced the same issue.
yesterday I was riding my vette at night and suddenly DIC massage appear ( Ice Possible ) + climate control + AC + seat heater switched off ( including the button's light ) for a seconds, then work again, then after a while it happen again many times then switched off permanently.
1 month ago i changed my navigation screen and thought maybe some wires are not well connected, I opened the center console and checked all connected properly.
I tried turn off and on the engine but still the same, Now I can not use the climate control + seat heater.
I googled the problem, also youtube but seems no one know about it.
please help because I need to use the AC as the temperature here reach 116 F and i have a black interior.
** note: the car have no heat issues.
Old Jul 11, 2022 | 11:32 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
All I can say, cause I never had that problem after my radio replacement, what I can tell you is A/C climate control isn't made anymore, so if it comes down after proper diagnoses your control head is bad.
I would look on E-bay for one I bought for friends Corvette that needed one.
I hope E-bay ships out of Country!
Old Jul 11, 2022 | 03:55 PM
kanvasman's Avatar
kanvasman
You have to disconnect 3 plugs in the climate control module to replace the head unit. I would make sure the plugs are securely in place. They are all different so they can’t be mismatched, but maybe not pushed in all the way. That would be where i would start.
Old Jul 16, 2022 | 03:12 PM
Jehad Tamim
2nd Gear
hello guys again,
after checking the wires, disconnect the battery and observe again, seems to be a fuse problem because all the center console's lights not working, i hope it's just a fuse and nothing else
To C6 climate control not working
