F55 Delete?
F55 system, besides the controller and wires, is the ride height sensors, and the MRC shocks.
So for the most part, F55 delete is done, when the $450 per shocks start to go bad,and they are changed out to standard type shocks isntead. Also to point out, the first C6 F55 programing where not the best, the systems was running the FE1 springs, so the system was really meant for a smoother ride in tour mode, and not to take the system up to a Z51 firmer set up in sports mode instead. This did change on the GS F55 models, since you have the FE3 set up, with MRC shocks instead.
Best guess, is the ride height sensors where not pulled, all that would need to be done is to reinstall the MRC shocks, then turn the F55 module back on in the BCM to take the car back to the basic base type F55 set up.
But, if it was not only just shocks, but other parts of the suspension system changed out to bring the suspension up to a Z51 or firmer suspension, then with the F55 system brought back in play with MRC shocks, would need to have the F55 firmware aftermarket re-flashed to get it correct instead (think at least GS firmware flash, is not more refined instead).
