What’s the difference?
Old Sep 27, 2022 | 11:25 PM
C3Angel's Avatar
C3Angel
Default What’s the difference?
U2107 is “Lost Communication with BCM” and U0140 is also “Lost comm. with BCM”
so my question is,
what’s the difference between each code?
Old Sep 28, 2022 | 07:30 AM
BlindSpot's Avatar
BlindSpot
A U0xxx code is a generic code used by all manufacturers and its specific definition is "LOST COMMUNICATION". Lost communication can mean lots of things and tends to be a "catchall" failure code.
A U2xxx is a manufacturer specific code. Each manufacturer can define codes specifically for their architectures and these codes help to further define or pinpoint problems. U2107 further diagnoses a short or open in communications with the BCM.
So, in your case, both codes are leading to the same problem, one further defines the other. The other thing with CANBUS architecture, since modules are constantly communicating, sending I/Os constantly, once a module drops offline for whatever reason, then as time goes on, more signals sent to this deadend node can produce more U-codes. Sometimes an entire long list of Ucodes has one failure point of origin. Once that correction is made, all the rest correct themselves.
Knowing this platform a little bit, my suggestion to you is - go to the passenger's side fusebox, look at the black box with multiple connections, check the integrity of those plugin connectors. It MIGHT be all that is needed to fix your problem. BE CAREFUL to first disconnect battery power, check the connections, power everything back up, do a global code delete, shut off accessory ignition, restart, check if codes returned.
Old Sep 28, 2022 | 09:01 AM
C3Angel's Avatar
C3Angel
well I was given U2106 code as well with the TCM and it was replaced. The BCM was replaced with a new one in July of 2021. Overall, I’m hoping this Used BCM can get reprogrammed
Old Sep 28, 2022 | 09:02 AM
C3Angel's Avatar
C3Angel
that’s if the BCM is the issue*
but thank you!
To What’s the difference?
