quick dumb question
Sep 29, 2022 | 02:46 PM
quick dumb question
2006 is there a way to turn off mirror map lights and leave floor lights on...Thx
Sep 29, 2022 | 03:11 PM
Have you tried turning the map mirror lights off by pressing the buttons in? That's the usual way they get turned off.
Sep 29, 2022 | 03:26 PM
Sep 29, 2022 | 04:58 PM
Sep 29, 2022 | 05:00 PM
Take the mirror light bulbs out.
Sep 29, 2022 | 05:30 PM
Quote:
Originally Posted by
Pb82 Ronin
Duct tape - it’s less work.
Sep 29, 2022 | 06:12 PM
I turn the little **** and floor and map lights turn on wondering if i can just turn on floor lights
Sep 30, 2022 | 12:38 AM
Turning the **** should adjust the brightness of the instrument panel lights. Pushing the **** in should turn the curtesy lights on or off. As mentioned above, you would need to remove the bulbs from the map lights to do what you're trying to do because I believe all of those lights are on the same fuse. You could try pulling that fuse to confirm that. It's in the passenger footwell under the toe-board.
Sep 30, 2022 | 12:45 PM
St. Jude Donor '10-'11-'12-'13-'14
FatsWaller
Yeah, those bulbs are hard to remove.
