I need help
Old Oct 6, 2022 | 03:06 PM
tommyracer's Avatar
tommyracer
Cruising
Default I need help
I have a problem, I took the radio out and tried to start the car, no luck, when I got the new touch screen in it and tried again, no luck, it tell me that FOB are not in the range, now the car won't start nothing. I changed the fuse for the radio. If you could provide some help?
Old Oct 6, 2022 | 04:41 PM
rockymountain1999's Avatar
rockymountain1999
2021 C6 of the Year Finalist - Modified
Have you tried putting your FOB into it's slot in the glove box?
Good batteries?
Are they programmed correctly?
Old Oct 6, 2022 | 09:52 PM
RodRamos's Avatar
RodRamos
It's pretty hard to diagnose given the information you've provided, however I do know the Corvette's electronics are highly integrated. It is possible something isn't electronically happy now. Do you have a check engine light on? Have you put an OBD2 scanner on the car?
Old Oct 6, 2022 | 10:09 PM
Vette_DD's Avatar
Vette_DD
This process doesn't use the battery in the fob. The car battery automatically furnishes the power. If the car will start when the fob is put in the slot in the glove box, try replacing the fob battery after you make sure how the new battery needs to be installed in the fob.
Old Oct 7, 2022 | 08:17 AM
Corvette_Dez's Avatar
Corvette_Dez
Try reconnecting the old radio and see if it starts.
Old Oct 7, 2022 | 11:55 AM
oldcanuck's Avatar
oldcanuck
You said, "now the car won't start nothing."
Maybe you ran down or toasted the car battery.
Old Oct 7, 2022 | 12:46 PM
gdmoore01's Avatar
gdmoore01
The RCDLR (remote control door lock receiver) is located just above the radio in the dash. Assuming you performed all of the radio removal/installation work yourself, it may be possible that you have accidentally disconnected the RCDLR or now caused some signal interference for the fob to connect properly. Double check that the RCDLR connector is properly seated into the module and be sure to remove any connection cables (phone charger or devices). Then disconnect/reconnect your car battery to perform a clean reboot of your electronic modules and try again.
Let us know your results.
GD
To I need help
