Using Tech2 on column lock
Old Oct 13, 2022 | 09:41 AM
lovinmyls1's Avatar
lovinmyls1
Default Using Tech2 on column lock
After eight years with a column lock bypass my DIC is showing service column lock. From info here on the Forumn I decided to go to my Chevy dealer to get them to " flash the BCM".They would not do it wiThout the tsb being done The bypass stops the lock from activating but the message is a pain in the butt. It goes away with the reset button but comes right back. My son has a friend with a Tech 2 but I'm sure he's never done a flash for this problem. Can anyone explain the procedure to do this or is it too complicated? If I
have to I will buy a new bypass but would prefer the flash. Thanks for any help.
Old Oct 13, 2022 | 02:41 PM
rbwinston's Avatar
rbwinston
Just went through the same thing, suddenly getting "service column lock" on DIC. Would disconnect the battery, reconnect it and it would go away for a while, then show up again. Finally took the car to a local independent shop who had a Tech2 and he flashed the BCM and took out the software. Charged me $100. Some dealers won't do it without removing the lock which involves removing the steering wheel and going into the column, then they also flash it and charge you $500!! I don't know the procedure, unfortunately, but do know the Tech2 will do the job. Try a PM to Dano523, bet he can tell you what you need to do.
