Phone problem
Old Nov 30, 2022 | 01:01 PM
Allen1947's Avatar
Allen1947
4th Gear
Default Phone problem
It's telling me I have a incoming call but can't answer it with the button on the steering wheel.
Old Nov 30, 2022 | 01:03 PM
madsonp's Avatar
madsonp
Are you running the stock, or an aftermarket stereo ?
Old Nov 30, 2022 | 01:26 PM
farmington's Avatar
farmington
Have you paired up with Bluetooth?
Old Nov 30, 2022 | 03:33 PM
Allen1947's Avatar
Allen1947
4th Gear
yes , it worked fine for about a year, then the button on the steering wheel wouldn't answer it the call. I could answer with the phone . The mechanic at the chevy dealership told me that gm stopped supporting it. Hard to believe..
Allen
Old Nov 30, 2022 | 03:45 PM
Allen1947's Avatar
Allen1947
4th Gear
I forgot to mention that the radio is stock,
Old Nov 30, 2022 | 03:46 PM
Allen1947's Avatar
Allen1947
4th Gear
Old Dec 1, 2022 | 01:46 PM
Rick369's Avatar
Rick369
Suggest the following.
1. Delete (unpair) your phone from the car. Delete the car from your phone. Start over and pair your phone to your car. Check to see if everything is working properly.
2. If suggestion 1 doesn’t work, disconnect your negative battery cable for 20 - 30 minutes. Reconnect your negative battery cable and see if that fixes the problem. You will have to reindex your windows after reconnecting the negative battery cable. This process has been known to fix a number of issues, as it resets the cars electronic modules.
Old Dec 1, 2022 | 07:44 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
If you answer the phone thru the phone while in the car does the audio work thru the car? If so can you hang up thru the car?
Old Dec 2, 2022 | 05:01 PM
wjnjr's Avatar
wjnjr
Allen
Ask Apple if they support a 13yr old iPhone, iPod/Pad, or Mac, and you will believe.
Old Dec 2, 2022 | 05:36 PM
MKenM's Avatar
MKenM
I have a 10 year old iPad that still gets iOS updates (running 15.7.1 right now).
To Phone problem
