Can anyone help me on this
My passenger door does not open from outside
I have changed the pressure switch on door and the door switch inside post
I have also changed the window regulator in door
still will not work
I have a new key fob battery
Door opens fine from inside
I had a similar situation as yours but mine did not want to open from inside or out. I could hear the door lock mechanism wanting to work but it just would not release. I replaced that part and mine worked. You have replaced everything I would have so a bit stumped. You could completely disconnect the battery wait 10 or 15 minutes and then let everything boot back up.
