Gate code
Old Jan 30, 2023 | 12:46 PM
samson308's Avatar
samson308
Default Gate code
Hi All, is it possible to add my HOA gate code to my 2013 C6 grand sport without deleting the codes that I have on my sunvisor? Everything I read tells me to hold the one and three buttons together until it blinks, but that seems to delete everything that I have previously programmed. I did it when I bought the car new but now I can’t seem to remember how.
Thanks, Sam
Old Jan 30, 2023 | 06:12 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Hold 1 and 3 for 2 seconds and then release. Then you can select the button you want to program. 2010 thru 2013 C6's did not use Home Link (they used Car 2 U) so it is unlikely that you will be able to program your front gate into your C6. I could not program the front gate for our community for the same reason.
Old Jan 30, 2023 | 06:29 PM
samson308's Avatar
samson308
Thanks, I’ll try it that way
Old Feb 1, 2023 | 09:05 AM
JABCAT's Avatar
JABCAT
Depending on the system your gate utilizes, you should be able to program it. I have my garages and my driveway gate programmed into my Z06. The gate uses a dip switch arrangement and it can be programmed by holding down the button in a specific pattern - instructions were on the Lear Car2U website.
To Gate code
