A gasoline question
I remember when gas hit hit 6.99 - 7.99 or more at Chevron in Southern California, that’s when I stopped looking at the price of super unleaded gas. Just tell me where it is and I’ll pay it off when the bill comes
"So, if you run regular in your supercharged Vette, does it make a difference if it's with an M6 or A6 transmission?"
More likely to lug the engine with an M6 which is certainly not a good thing when pinging is an issue. An A6 with a really loose (high stalling) converter might help.
"For those that add octane booster...are you careful how much you put in and to which tank it goes into?"
I like to be pretty precise about most anything I do so yes, I use Boostane's handy dandy mixing chart. I err to the side of caution as too much is no problem but not enough spells KABOOOOOM!!!
I only have one gas cap so I don't have any means to fill the right side directly so I just do the convenient thing and assume that it'll be fine and somehow mix itself thoroughly before I can pull out of the gas station. So far so good. No KR at WOT.
"MMT is a manganese compound, which like lead, does not vaporize in the combustion chamber. It exits the engine as extremely small, but fully solid metal particles that plug the pores in cats."
LDB brings some very important info to the discussion. I probably wouldn't make a regular habit of octane boosters with cats and I can tell you from experience that leaded gas (AV gas is "low lead") is a serious no-no
unless you enjoy changing O2 sensors. Back in the days before unleaded race gas was really a thing (late 90s, very early 2000s) I was running AV gas at the drag strip on the weekends and I had to keep a few spare sets of O2 sensors with me to swap out at the track. Sometimes I'd get a dozen passes, sometimes a few dozen passes out of a set. That gets expensive quick! And then they invented unleaded race gas which cured that problem. Ahh....those were the days.
"Back in my day we didn't have unleaded race gas or octane boosters that actually worked!""It exits the engine as extremely small, but fully solid metal particles"
Yep, I accidentally shot out a guy's front windshield and knocked a squirrel off of a mailbox just last week. Truly, this stuff can be dangerous!
From my 20 minute search, I found a draft MSDS for the unleaded G100UL fuel, and it said 40-60% alkylate, other isoparaffins totaling 5-25%, and various aromatics (mostly xylene) totaling 20-50%. It did not mention MMT, so I was still scratching my head about where the octane came from. Then I noticed that one of the lines my eyes had originally read as toluene was actually 0-6% toluidine. Ooops, toluidine is not a refinery product like everything else mentioned on the MSDS. It is a chemical that is closely related to aniline (see aniline issues in post #59), with just one more methyl group hanging on the side of the aniline molecule. So that’s undoubtedly where the octane boost is coming from. I do not know anything of substance about the corrosivity of toluidine, but with molecular structure so close to aniline, I’d certainly be worried about it if I were a pilot considering such a fuel. One would hope they have done their homework, and it’s either surprisingly and substantially less corrosive than aniline or they have some other corrosion mitigating approach. But I’d want to know the facts in that area with certainty before putting it in my car, or if I owned one, airplane.
I mentioned I use it but my car is fully set up for it (by Vengeance Racing). Pretty awesome stuff.
Two carbon chains, one is zero octane and one is 100 octane.
You can go anywhere from zero to 100 octane just by altering the carbon chaining of hydrocarbon molecules in a gasoline.
The difference is due to carbon chain packing and steric hindrance which limits accessibility of oxygen radicals to carbon electronic configurations.
Magnuson Superchargers recommend that you run a minimum of one (1) tank of premium fuel through your vehicle prior to installation of the system to prevent any possible damage that may occur due to running the supercharged engine on lower octane fuel. Do not use any Octane Booster”
