Possible causes
Old Mar 1, 2023 | 07:24 PM
BLUDICE's Avatar
BLUDICE
Default Possible causes
The dealership says that my car has a burn up fuel pump relay - has anyone experienced this with their car - what was the cause
Old Mar 1, 2023 | 09:52 PM
JasonAndrew's Avatar
JasonAndrew
do you know how to use an ohm meter? Quite simple to troubleshoot.
Old Mar 2, 2023 | 12:00 AM
gdmoore01's Avatar
gdmoore01
A possible cause would be that the relay may have arc'd and burned due to movement within the underhood fuse block. The fuse block consists of 3 levels sandwiched and held together by crimped metal rivets and the 4 bolts that run through them on the top of the block. Assumed that the dealer replaced the relay. You should pull it and check the connections below for any receded and/or burned contacts. If confirmed, the new relay may just burn as well.
There are threads that describe how to pull the fuse block apart and straighten the contacts or pull them up & straighten them to maintain better connectivity.
GD
Old Mar 2, 2023 | 05:30 AM
BLUDICE's Avatar
BLUDICE
GD
the tech is replacing both the relay and the fuse block
Old Mar 2, 2023 | 05:52 AM
Spaceme1117's Avatar
Spaceme1117
Sometimes relays just go bad and burn out. Lot of power running through them.
Old Mar 2, 2023 | 08:35 AM
FatsWaller's Avatar
FatsWaller
Two ways I can think of: the insulation on the electromagnet coil degrades and the coil shorts out. That will burn up the coil if the fuse doesn't blow. Second way is if the contacts which carry the high amps are worn or dirty and start to arc. Nothing like an electric arc to generate heat.
Old Mar 7, 2023 | 01:57 PM
BLUDICE's Avatar
BLUDICE
Additional info: after replacing fuel pump relay and fuse block, LS fuel pump found to be incapable of putting out enough pressure to run engine- has to be replaced.
Old Mar 7, 2023 | 02:21 PM
1Hotrodz's Avatar
1Hotrodz
So what the Tech is most likely concluded is: the pump had a bad (shorted)commutator which in turn resulted in a high Amp draw of the motor. This high amperage draw will stress out the components up stream of the pump and including the pump. Things like relays, wires, fuses, connectors, etc..
Besides the electrical aspect, also check for : on the fuel side for clogged pick-up filter or filter sock and discharge(pressure) side fuel filter.
Old Mar 7, 2023 | 02:47 PM
hazy's Avatar
hazy
@BLUDICE
since your car is already supercharged, this could be an opportunity to spend a little extra money and upgrade fuel pumps while you're at it. The boost-a-pump that's (presumably) installed might just be pushing the stock fuel pump to the limit, leaving no room for error. Upgrade the fuel pump means a little more money, but a fair bit more peace of mind that you won't have any issues going forward
Old Mar 8, 2023 | 12:33 PM
myfunz's Avatar
myfunz
I noticed my fuel pump relay was turning brown on the side of the relay so I replaced it.
To Possible causes
