BCM lost settings for TPMS
Old Mar 8, 2023 | 11:16 AM
Tom Gilfoy's Avatar
Tom Gilfoy
Default BCM lost settings for TPMS
I changed my gauge panel to get the mileage back to original from the temp gauge panel I put in when the original went bad( and no I could not find anyone to fix it I tried). Any way the TPMS settings went back to zero I guess when I disconnected the battery. I was able to reprogram them but thought it was odd that that happened maybe batteries are getting low?
Old Mar 8, 2023 | 11:21 AM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
How old are the TPMS? How much have you driven the car since the panel was replaced? What year is the Vette?
Old Mar 8, 2023 | 04:20 PM
FatsWaller's Avatar
FatsWaller
You didn’t need to reprogram them. The TPMS id’s are stored in the RCDLR’s NVR. The last pressure readings would have been erased with the battery disconnect which explains the 0 reading, but the sensors should report around once per hour if the car is not moving, and about every minute once you exceed 20 mph.
Old Mar 9, 2023 | 08:51 AM
Tom Gilfoy's Avatar
Tom Gilfoy
I reprogramed them anyway so now I'll check it next time I drive it. I don't know if the previous owner changed them when they put tires on, actually I should have stupid me.
Old Mar 9, 2023 | 08:53 AM
Tom Gilfoy's Avatar
Tom Gilfoy
I don't know how old they are ,I dought they are original from 05. I reprogramed them and it worked so I'll check in a few days when I drive it.Thanks
To BCM lost settings for TPMS
