Shift cable bushing?
Old Mar 17, 2023 | 08:38 AM
BLUDICE's Avatar
BLUDICE
Default Shift cable bushing?
The car in in the shop getting the fuel pump replaced so would this be a good time to replace the shift cable bushing at the transmission or is this no longer a concern with this new of a car?
Old Mar 17, 2023 | 09:05 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I wouldnt fix it unless its broken... My 13 has 140k on it and no issues. I don't think its as wide spread as folks make it out to be.
Old Mar 17, 2023 | 09:07 AM
FatsWaller's Avatar
FatsWaller
Your car's not that new, and the bushing at either end can fail, so either replace both bushings, or the cable. Will your dealership even replace the bushings, though? They'd have to use aftermarket parts. There's no OEM bushings.
Old Mar 17, 2023 | 09:17 AM
C6ToGo's Avatar
C6ToGo
I wouldn't replace......but I might heat wrap the part of exhaust pipe near that linkage. I did mine.
Old Mar 17, 2023 | 10:13 AM
FAUEE's Avatar
FAUEE
It's just plastic, so it can go at any time. That said, of the car is garage kept, it's likely fine. They're cheap and easy to do though. I wouldn't bother I guess
Old Mar 17, 2023 | 01:05 PM
SixAddict's Avatar
SixAddict
If I was you and the service department has the cradle and torque tube down for access to the tanks, I would have them install a new cable.
New cable is cheap and since they are “right there” why not.
I replaced the cable during engine work and trans service and it wasn’t that much more of an expense. Your call.
Old Mar 17, 2023 | 07:51 PM
Jailor97's Avatar
Jailor97
Leaving it alone is all fine and dandy until you can't shift it and you are far from home.
Mine crapped out the day before our last PCS move.
Replace it if is already at the shop.
Old Mar 17, 2023 | 09:22 PM
ZSkipper's Avatar
ZSkipper
No fun when the bushing snaps...mine went on my 2008 at a traffic light...lots of 'waves' from passing motorists until AAA arrived. I just picked up a 2013 A6 with 90k miles, and will be replacing the bushings next week from https://www.corvettepartscenter.com/collections/c6/products/transmission-shift-cable-repair-kit. Cheap insurance!!
Old Mar 18, 2023 | 11:41 PM
enventr's Avatar
enventr
No fun when it goes as I recently had a flat bed tow truck tow me.
Old Mar 19, 2023 | 02:26 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
No warning when my 2006 broke. Sitting at the fuel pumps in the rain. Roll back driver was great and roadside service picked up the tab. Dealer had part on hand and got me back on the road. I was 8 hours from home. I now carry a spare cable with me.
Old May 26, 2025 | 03:21 PM
LouWinget's Avatar
LouWinget
Default Replacing Shifter Cable Bushing on an A6
That old adage about "If it ain't broke don't fix it" should not really apply in this instance (IMHO). The reason: there is no warning before it breaks, and when it does you will not be able to shift from whatever position the transmission is in. If this were to happen in your garage, okay fine! But what are the chances if that? Knowing that this part is very susceptible to breaking, and with no warning, and leaving you stranded - why not take the preventive maintenance action.
To Shift cable bushing?
