When I push the switch to turn car off the accessory light stays on. Push it again and the ignition light comes on. They both won’t turn off at the same time. Any thoughts??
it’s the two lights on the switch. There may not actually be a problem. I had a radio installed and before you pushed the button to turn off the car and pushed it again and the red
lite when off and the yellow light went off. Now they both won’t turn off. Push the button once and the red goes off but yellow is on. Push it again and the yellow goes off and red comes back on. Push it a third third time and the yellow goes off but red comes on. Open the door and red goes off and the green comes on but only for about 10?seconds then all is fine
As noted by wjnjr, this is normal behavior due to RAP. At least, what you describe is what my Z06 does.
