Air filter thoughts?
Old Mar 20, 2023 | 02:28 PM
SD44's Avatar
SD44
Default Air filter thoughts?
Guys, what are your thoughts on best air filter for the c6? I have always been a k&n guy but am rethinking this for my cars. I'm thinking Wix may be best for my GS. Your experiences here are valued help for me.
Popular Reply
Mar 20, 2023, 04:26 PM
FatsWaller's Avatar
FatsWaller
ACDELCO
Supplies all the air an unmodified LS can use while at the same time scoring at the top for particle removal.
Old Mar 20, 2023 | 02:45 PM
Dzv69's Avatar
Dzv69
I'm running a WIX 49997 from RockAuto. Absolutely no complaints.
2012 GS M6
Old Mar 20, 2023 | 03:13 PM
Vette_DD's Avatar
Vette_DD
Don't forget that your car has 2 air filters. One for the engine and one for your car cabin.
Old Mar 20, 2023 | 03:30 PM
blownbayou's Avatar
blownbayou
Running AEM dry filter......
Old Mar 20, 2023 | 04:26 PM
FatsWaller's Avatar
FatsWaller
ACDELCO
Old Mar 20, 2023 | 04:35 PM
SD44's Avatar
SD44
yes sir, already swapped out the cabin, which was a mess and not properly installed by whomever. Thanks for the reminder though!
Old Mar 20, 2023 | 05:55 PM
Beastifus's Avatar
Beastifus
Slightly less expensive, works great, this STP one from AutoZone: https://www.autozone.com/filters-and...782/466671_0_0
Old Mar 20, 2023 | 09:06 PM
sirdano's Avatar
sirdano
I went AFE also. Mine is a 2009 with the z06 like filter. Darn paper one is 150.00. This reusable was 112.00
Magnum FLOW Pro DRY S Air Filter
Old Mar 21, 2023 | 09:18 AM
El_Steveo's Avatar
El_Steveo
Many high performance air filters that don't expand the filter surface area achieve their performance my increasing the size of the "holes" in the filter media. this increases air flow, but reduces the filtration capability of the filter. I say this to say that if this is a performance car and driven as such, get a K&N or something of the sort. If this car is your collector/weekend cruiser, get a factory replacement air filter.
Old Mar 21, 2023 | 09:23 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I would say dont put that much thought into it, your talking increments/fractions of horsepower between filters...
Old Mar 21, 2023 | 10:28 AM
FatsWaller's Avatar
FatsWaller
Old Mar 21, 2023 | 12:43 PM
Colonel's Avatar
Colonel
If by "best filter" we mean for HP then a properly sized K&N type (oiled cotton/gauze) is about as good as it's gonna get, IMO, and it's been that way since I was a kid. You'de think they'd have come up with something better by now but no.
And if by "best filter" we mean for actual filtering performance then a good 'ole AC Delco is hard to beat.
I run stock filters in my stock slow carsand cotton/gauze in my fast cars.
Old Mar 21, 2023 | 08:03 PM
Dzv69's Avatar
Dzv69
Originally Posted by FatsWaller
Any possibility these charts are available for an ACDelco A3107C and a WIX 49997 ?
Old Mar 21, 2023 | 08:23 PM
Corvette_Dez's Avatar
Corvette_Dez
Go with K&N. It's a great quality filter, made to go a million miles. And it's made right here in the good 'ol USA.
Old Mar 21, 2023 | 08:35 PM
FatsWaller's Avatar
FatsWaller
It’s unrealistic to try to test and compare every model of every manufacturer’s filter. No one has the time or money to do that. What those tests showed was examples of commonly used filters using those manufacturer’s materials and technology. Probably doesn’t make that much difference to engine life unless you want to go a million miles. Literally, YMMV.
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
AC Delco Engine Air Filter: A2945C, AC Delco Cabin Air filter: CF131C
The two-piece open-end stock air box with dual AC Delco filters are my choice for my '06.
Old Mar 21, 2023 | 08:42 PM
Corvette_Dez
Ooh ooh, I want to go a million miles!! Lol
To Air filter thoughts?
Old Mar 21, 2023 | 08:51 PM
ck9887's Avatar
ck9887
How about an OEM LS9/ZR1 filter …
I believe they are a direct fit for LS3/LS7’s and supposedly flow better. I’m currently considering one for my 08 Z06
Old Mar 21, 2023 | 11:30 PM
Dano523's Avatar
Dano523
Oiled filters don't start to even get close to filtering until they get a little dirty, and the amount of crap they let through even then, forget about it. The add in the fact that over oiled filters will cause problems with the MAF sensor as well.
Note, when changing the air filter, make sure to pull the Maf filter to use Maf cleaner to clean them. The stock dry filters will not cause problems like the oiled filters, but still need to clean the Maf sensors from time to time.
Simply, the stock type dry filters already outflow the motor demands, and since they do the best at filtering to begin with, the reason to use them.
As for filters, love the Wix golds, sinceas good as the oem filter in filtering and air flow, and prefer them over the GM filter since they are white, not dark, and you can see when its time to change the filter over just guessing.
Old Mar 22, 2023 | 12:57 AM
sirdano's Avatar
sirdano
Do a Google search on what do Baja racers use for air filter. You will be amazed
