Front suspension
Old Mar 24, 2023 | 03:39 PM
rjf952's Avatar
rjf952
1st Gear
Default Front suspension
When I make a turn at low speed like in a parking lot I can hear a ticking sound coming from the front brake area. I'm not sure it's from both sides but I know that it's from the driver's side. I took both front tires off and couldn't find anything hanging or rubbing. Any thoughts?
Old Mar 25, 2023 | 09:06 AM
dr_gallup's Avatar
dr_gallup
Is this at full lock? That's normal with these wide tires.
Old Mar 25, 2023 | 01:22 PM
kestell123's Avatar
kestell123
I had the same noise when the runflats got old and hard, with new non runflat tires this is nearly gone.
Old Mar 26, 2023 | 08:09 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Might be a loose center cap. As they age and get brittle the plastic spring ears break off and sometimes can make a ticking sound as the wheel rotates. You can check them by tapping on them with your finger. If the cap makes a noise it is loose.
Old Mar 26, 2023 | 11:27 PM
PCMusicGuy's Avatar
PCMusicGuy
At full lock the steering pump could also be making the ticking noise. That sound is pretty normal.
To Front suspension
