Interior Leak!!!
Old Apr 4, 2023 | 05:33 PM
Ahrmike's Avatar
Ahrmike
Default Interior Leak!!!
Wondering if anyone had the same issues I've had -
Driving in heavy rain over the past week and my driver side carpet got SOAKED. Passenger side is bone dry.
Thought it might be from top/drain - after I pulled the carpet, seats, etc, I dried it off. Overnight, it rained again - with zero intrusion into the cabin.
I poured some water into the drivers tub and noticed a drip coming through the seat bolt holes. Thinking MAYBE this might be the cause? Anyone have any thoughts? Poured water on the driver side A pillar - water poured out of the fender, none came into the cabin. Same deal with hatch - poured water directly into the udder with the hatch open, no intrusion. I also didnt notice any water leak marks coming through the firewall on the clutch/brake cutouts.
To be fair, the water i drove through was DEEP. like, probably 4-5 inches deep + higher with the wake being pushed by other cars. I did see a car hydrolock right next to me as I was driving through it too.
Thinking of sealing the seat base with pliable butyl + washer..?
TLDR
Water on one side.
Checked top, rear udder, front udder.
Checked clutch/brake cutout.
Seat bolts weep a little water.
Any other places I should check?
Old Apr 7, 2023 | 09:46 AM
H8 mondays's Avatar
H8 mondays
While the butyl and washer will seal the hole. While I'm not afraid to drive my C6 in the rain if cars are hydro locking next to me I will find a way around that lake. My C6 is a car not a boat. Good luck
Old Apr 7, 2023 | 10:16 AM
sramzzz's Avatar
sramzzz
You can get a C8 that is a boat.
Old Apr 7, 2023 | 11:05 AM
H8 mondays's Avatar
H8 mondays
That's just down right wrong destroying a good boat and putting an ugly c8 on top.
Old Apr 7, 2023 | 01:31 PM
DrKrieger's Avatar
DrKrieger
Probably having water intrusion from underneath. Get under the car and take a close look. Also check your door sill seal. The drain being plugged behind the right fender could also be a problem.......let us know what you find. Good luck.
Old Apr 7, 2023 | 08:20 PM
Ahrmike's Avatar
Ahrmike
Thanks all - seems like its a pretty rare issue then. I daily drive the C6 and i drive it in all weather (no snow here!). It was a freak rainstorm that dumped 4-5 inches in half an hour or so.
The seat bolts definitely leaked some water upwards into my cabin so im hoping I've solved the issue. I also read about the butyl tape sealing the floorpan from beneath in front of the passenger and driver seats and those were still on and sealing.
If I see any more leaks in the future I'll update this thread for posterity. If NOT, and you find yourself in a similar situation - seal your bolt holes!
The car that hydrolocked near me couldnt read deep water for sh*t. I was driving on the road crown and he was making a right turn. instead of making a wide right off of the crown, he went straight into deeper water at the road edge...
To Interior Leak!!!
