Weird noise
Old Apr 7, 2023 | 02:40 PM
Vinnie Campi's Avatar
Vinnie Campi
1st Gear
Default Weird noise
So I was driving and started smelling gas and thought it was weird so I pulled over and I saw gas fumes coming out of the gas cap area so I opened it and the gas cap and it released air almost like it was pressurized
Old Apr 7, 2023 | 02:59 PM
ClothSeats's Avatar
ClothSeats
Sounds like the purge canister vent valve has failed. That valve is normally open, which prevents any buildup of pressure in the EVAP system. You should get a DTC if that is the case.
