Battery tapered nut thread size
stangin4lyfe (04-11-2023)
Actually, I just bought a 2013 GS.
It came with a pretty decent amp and radio system. I was getting intermittent turn on problems
and found the negative wire to the amp and crossovers was loose.
Whoever installed the system did a decent job. However, they used the existing threads on the battery terminals
to attach the wires for the amp. They used brass nuts and it appears they self threaded onto the studs that are used for
tightening the battery terminals to the posts.
I would really like to find the correct nuts to be able to tighten the amp wiring tightly.
jaki30 (04-10-2023)
No, did you need some? Amazon has some. I used to Live in Williamsburg a long time ago, love it there.
https://www.amazon.com/Dorman-926-87...s%2C163&sr=8-1
I went to the stealership and was told that I had to buy the entire cable and could not purchase just the nuts.
So I ended up taking a M6x1.0 nylon locking nut(due to it's head design) and reversed it and hasn't failed me since but I wish I knew these were out there at that time!
